Anyone with a GT3076R
The reason it spools faster is because with the stiffness of two springs the wastegate stays closed and does not leak boost prematurely. Premature boost leak from the wastegate will kill spool.
Originally Posted by jj_008
Have you guys noticed that the turbo seems to spool a little faster as it gets broken in? It seems like mine is starting to spool a little better.
BTw, I use the the big blue spring and small yellow spring. It gives me 18psi w/ out boost control. Also, the guys at ATP told me that 2 springs gives better spool up and less boost spikes.
BigT
Aug 3, 2009 02:15 PM
hokiruu
Sep 29, 2007 11:32 AM
