clunk noise from front end of car
Old Apr 11, 2005 | 06:57 PM
forum04pl's Avatar
i have an 03 evo with 22k on it and the last few days or so i have been getting a clunking noise from a dead stop when i turn or if i am driving slow in 1st and cut the wheel either way it will clunk once each time i cut the wheel. it seems to be driving fine but i am going to get it checked out. what could it be?
Old Apr 11, 2005 | 07:21 PM
ex-honda's Avatar
Check your suspension. Something might have gotten loose. Also this problem has been occuring on alot of the Evo ever since. It is the top mount of the coil springs perches. When take a turn, alot of times the spring is moving and reseating itself and that is where you get that clunk. Other buy the Cusco pillow ball mount and the noise goes away.
Old Apr 11, 2005 | 07:24 PM
forum04pl's Avatar
i am running the tein flex setup. but the noise also occurs if i am at a stop then pull forward while turning
Old Apr 11, 2005 | 07:27 PM
ex-honda's Avatar
I got the Flex also. How long have you had the Flex?
Old Apr 11, 2005 | 07:30 PM
forum04pl's Avatar
about 4 months... any other ideas on the clunk
Old Apr 11, 2005 | 07:32 PM
ex-honda's Avatar
Ya. Hold on. I am going to take a picture of the problem so I can show it to you. Give me about 5 mins.
Old Apr 11, 2005 | 07:33 PM
stevEVO8's Avatar
I had the same problem; it started out when I took off pretty fast and then progressed to making the clunk when turning.
Mitsu retorqued all of the bolts etc on the front end and it went away.
Old Apr 11, 2005 | 07:53 PM
ex-honda's Avatar
Okay on the Tein. Check the big nut on top of the coilovers. Alot of times from the factory, they are not that tight. When I first installed mine, it looked tight but when I installed them, they were "clunking" like crazy. Sorry for the big picture. Here is a picture of what I am speaking of:
Old Apr 11, 2005 | 07:59 PM
forum04pl's Avatar
its definatly not that, i tightened those really tight when i first put them on becuase they did the same thing you described, i also checked them already to see if that was it
Old Apr 11, 2005 | 08:01 PM
DCSilvrEvo's Avatar
didu change your clutch ? It happens to me but now it stoped
ex-honda's Avatar
Then check the springs on how they sit on the rings. they could have shifted or gotten loose.
Old Apr 11, 2005 | 08:13 PM
forum04pl's Avatar
yeah im going to go through the susp. tomorrow, i am on the stock clutch. i am mainly worried that it could be the front diff. but i honestly have no idea. what worries me is that if i am stopped and i give the car some gas and let out the clutch as im pulling forward the clutch chatters a little because it is worn and the car makes a clunk noise everytime it chatters. but if i am driving and cut the wheel either way it will clunk. if it was the front diff would it clunk if i was cutting the wheel while driving?
Old Apr 11, 2005 | 08:29 PM
Turbo Meg's Avatar
I think I had the same problem it seems like it comes and goes. I get it from a dead stop if I turn the wheel sharply left or right. It sounds like a clicking or rubbing sound. I have been back to the dealer twice but it alway goes away before they can diagnos and fix it. I also seem to get the problem after my car is sitting for a week or so then it goes away 100 miles later?
Old Apr 11, 2005 | 08:35 PM
MYEVOVIII's Avatar
My car is stock with 16k and it does this also front left drivers side. I got underneath it and above it and everything seems tight cant figure it out. Dealership here I come o'h well I guess I 'll have them fix my calipers as well.
Old Apr 11, 2005 | 08:40 PM
Wicked's Avatar
mine is doing it too, but only if I drive forward, stop, cut the wheel to lock, then reverse.. then it will clunk.. same prob?
