View Poll Results: what trany fluid to use?
GM Synchromesh
7.14%
Penzoil Synchromesh
16.07%
BG Synchroshift I
37.50%
Redline MT90 or MTL
19.64%
Royal Purple
8.93%
Other
10.71%
Voters: 56. You may not vote on this poll
trany fluids to use.
Old Apr 16, 2005 | 08:52 AM
QAT-R's Avatar
BEWARE OF REDLINE! do a search and you'll see what I mean.
So time ago I read some posts that directly attributed redline to gear failure. Jon from TRE even posted a warning about it.
Old Jan 24, 2006 | 08:08 AM
BBYBruno's Avatar
Redline
Old Jan 24, 2006 | 08:15 AM
akEvo's Avatar
i use syncromesh now, but i saw that amsoil and royal purple are both comming out w/ thier flavor of syncromesh (GL4 - 80w)
Old Jan 24, 2006 | 10:13 AM
oak2207's Avatar
Originally Posted by Mercenary3
Persoanlly I would recommend stock fluids unless you want to use something less expensive. Unfortunately, the most obvious choice- stock- isnt listed.
If your using a fluid to correct notchy/grinding shifters...I would recommend fixing the tranny, not the fluid. The stock fluid works and works well...its the metal that isnt working right. Synchromesh, etc can give you better shifting, but at a trade off for better gear lubrication. So a lubricant that is good for synchro engagement might not be good at all for gear wear. Fortunately I havnt heard many complaints on tranny gears failing...so hopefully it works OK.
Anyways, Im voting stock, even though the poll doesnt accept my choice.
Also, FYI- GM and Pennzoil synchromesh are the exact same oils only in different bottles. One choice on the poll would suffice.
I second this. Stock fluids for me. Almost 44k miles on the tranny now with the only fluid change at 30k. Up until about 10k my tranny was super notchy, especially the 1-2 shift. Now it is pretty much smooth in all gears, 1-2 will clunk every now and again, but nowhere near what it used to be. I had a friend put in redline and it really jacked it up. So I stick with stock.
mr_lancerlot
48
Apr 22, 2012 03:01 PM
badhabit90
51
Nov 30, 2008 09:31 PM
GTS08
Lancer Aftermarket Forced Induction Tech
Aug 30, 2008 06:52 PM
Haste
Southeast Region
58
Apr 7, 2004 11:11 AM
