AEM vs. GM map sensors?
Old Apr 15, 2005 | 03:57 AM
EVO8LTW's Avatar
I'm trying to decide whether to get an AEM 5-bar map sensor or a GM 3-bar map sensor to use for datalogging purposes and to wire up an electronic boost gauge (Innovate XD-1). The AEM is more expensive, but if there are definite advantages to it then I'd rather spend the extra coin.
Thanks.
Old Apr 15, 2005 | 08:08 AM
bolsen's Avatar
Go with the GM
Edit: Also remember to get the pigtail, many times it doesn't come with it.
Old Apr 15, 2005 | 09:20 AM
BadazzCR's Avatar
The aem map sensor uses a steel body and can be threaded into the manifold giving a better reading, also the aem sensor is more senstive and can get you a greater resolution. Both are very good sensors but the aem is a much better unit. I would however use the 3.5bar aem unit as the 5 bar sensor has less resolution since it covers a much larger range.
GM 3 bar map reads up to around 26psi,
AEM 3.5bar map reads up to 34psi
AEM 5bar map reads up to 56psi
Old Apr 15, 2005 | 11:56 AM
EVO8LTW's Avatar
Are you talking about drilling and tapping the manifold, or is there already a place where it can screw in?
Old Apr 15, 2005 | 01:23 PM
BadazzCR's Avatar
Drill and tap it, but you will need to remove the manifold to do it. It isn't neccesary to tap it but to get the most accurate reading i would do it.
Old Apr 15, 2005 | 01:57 PM
bolsen's Avatar
How do you get those numbers? I was under a different impression...
Old Apr 16, 2005 | 06:47 AM
JustDSM's Avatar
.. PSIA and PSIG
Old Apr 16, 2005 | 06:52 AM
nothere's Avatar
isn't the innovate XD1 an AFR gauge? maybe it can also output boost(?)
Old Apr 16, 2005 | 07:10 AM
JustDSM's Avatar
The XD-1 is a "add-on" gauge accessory for the LM-1/LC-1. If used in conjuction with the Aux-Box you can have the XD-1 display the various inputs the Aux-Box recieves. Its completely programable.
10isace
Mar 13, 2016 03:09 PM
jameswwt
Sep 30, 2015 09:35 AM
MR
36
Mar 27, 2010 10:51 PM
Evo8uk
Sep 15, 2009 02:18 PM
joosdawg
Jun 17, 2007 12:13 PM
