Mmmmm, precious.... (BWW)
Old May 12, 2005 | 12:25 PM
  #61
marksae's Avatar
Originally Posted by EFIxMR
my 3071r bullet housing finally came!
What do those holes around the compressor inlet do? Is it some sort of anti-surge thing?
Old May 12, 2005 | 12:31 PM
  #62
strongbear0's Avatar
Yes it will drop right in. Get the koyo radiator for the evo VI and it will work and the outlet of the radiator is lined up perfectly with the inlet on the motor. There is a local guy that has the koyo evo VI raidator on his VIII and this is the route that I will be going.
Originally Posted by blitz118
Will the EVO VI radiator work on the EVO VIII? Do you know if it will drop in without having to modify anything, but the radiator hoses?
  #63
EVO8HKS's Avatar
looks awesome!
Old May 12, 2005 | 12:33 PM
  #64
1NastyEvo's Avatar
Holly sh*t !
Old May 12, 2005 | 01:40 PM
  #65
trinydex's Avatar
that is indeed surge porting. what happens is the oncoming air goes into the holes and reaches the bottom of them and then tries to pop back out. this effectively creates a pressure differential between the inlet and the rest of the comp housing.
they do this because if the air comes on too fast, if the airspeed attempting to go over the wheel is too great then you get wing stall (wheel stall). also if your compressor flows too much for your hot side you will get surge.
surge poring fixes both problems by reducing inlet velocities, it's basically introducing the perfect restriction because nothing is more smooth on air than more air.
Old May 12, 2005 | 03:31 PM
  #66
propellerhead's Avatar
Where did you send the housing out to be ported?
Originally Posted by trinydex
that is indeed surge porting. <snip>
Old May 12, 2005 | 03:48 PM
  #67
EFIxMR's Avatar
This one is a custom built turbo from precision. not sure if they modify turbos made by other people.
Old May 13, 2005 | 07:09 AM
  #68
EVO8 WHOA's Avatar
precision did mine too
Old May 13, 2005 | 08:17 AM
  #69
trinydex's Avatar
i believe agp also offers turbos with surge porting.
Old May 13, 2005 | 08:30 AM
  #70
Az3ar's Avatar
I am still here for help bud.. let me know
Old May 18, 2005 | 09:43 PM
  #71
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
Any updates on this ????
Old May 18, 2005 | 09:50 PM
  #72
I'm dragging my *** but it's moving along.
Old May 19, 2005 | 09:05 AM
  #73
M3this's Avatar
Sweet! ... I cant wait to see what type of power your making as I'm really interested in the full-race manifold and DP
Old May 19, 2005 | 09:39 AM
  #74
CeeNiK's Avatar
wow your manifold is sick
Old May 24, 2005 | 09:16 PM
  #75
Chris@nolimitmotors's Avatar
<---- selling 19" volks for almost same setup. I'll be running a SC61 with 4 bolt exhaust side though. But i'll have the same manifold/downpipe, i'll post pics once installed
