Different gear fluids for 2005 Evos?
Old Apr 29, 2005 | 12:45 AM
JT-KGY's Avatar
Just wondering... since that 2005s comes with ACDs... does it need different
gear fluids?
I used to run MT-90 for my transaxle with ok results... want to try something else.
Heard of Pennzoil Syncromesh... and some Neo product (dont know the full
name)... any other recommendation for the transaxle?
For the transfer case and rear diff, I ran Amsoil Series 2000 75w90... but Amsoil
have discontinued that product... so I'm now looking for replacement...
Need recommendation as well... I assume 2005 front and rear diff could run
the same fluid
Thanks!
Old Apr 29, 2005 | 12:57 AM
JT-KGY's Avatar
Found this:
I might use http://www.amsoil.com/storefront/svg.aspx for front & rear diffs...
Old Apr 29, 2005 | 06:56 AM
4-BNGR's Avatar
I only use and recommend that everyone only uses http://www.neosyntheticoil.com/ products. They are notches above anyone else...
4-BNGR
Old Apr 29, 2005 | 11:24 AM
JT-KGY's Avatar
Thanks 4-BNGR.. but I can't find spec nor price from the site... where could I
get more info?
I assume you use 75-90 HD or 75-90 RHD for all 3 gear locations?
4-BNGR
Old Apr 29, 2005 | 11:43 AM
JT-KGY's Avatar
Ya.. found more info on Neo's website...
75w90 HD looks like a GL-4... for transaxle:
http://www.neosyntheticoil.com/75w90hd.htm
75w90 RHD looks like a GL-5 can be used for front & rear diffs:
http://www.neosyntheticoil.com/75w90rhd.htm
or..
75w90 EP for all?
I also heard of use of GM gear oils... forgot the name...
Old Apr 29, 2005 | 12:08 PM
JT-KGY's Avatar
Never mind.. GM's syncromesh is the same as Pennzoils...
But Pennzoils doesnt even have a GL rating.. not putting that in my car.
http://www.pennzoil.com/products/gea...cro_fluid.html
Old Apr 29, 2005 | 12:10 PM
4-BNGR's Avatar
Neo is out of CA. You probably have a local dealer...
Old Apr 29, 2005 | 12:41 PM
JT-KGY's Avatar
Found more data thru search on this site..
Pennzoil/GM syncromesh:
http://www.stealth316.com/2-pennzoil-synchromesh.htm
BG syncroshift:
http://www.slowboyracing.com/Drivetr...ynco_info.html
Both are very thin oil....
Redline MT-90 whitepaper:
http://www.redlineoil.com/whitePaper/13.pdf
kyoo
12
Aug 16, 2010 06:06 PM
sdfontanini
36
Feb 6, 2009 10:33 PM
itsme4g63
34
Mar 3, 2008 02:57 PM
Derek888
14
Nov 21, 2005 12:55 PM
limey
Jun 28, 2003 02:06 AM
