Need to know ASAP!
Old Apr 29, 2005 | 10:28 PM
Cirrusly Evolvd's Avatar
Need to know ASAP!
I've been searching the net but can't find the answer I am looking for. I ordered a set of Samco coolant hoses and I need to know what the inside diameter is of the hoses. I am looking to get a water-temp sensor adapter but I need to know what size to get. If anyone can help me out here I'd appreciate it.
Old Apr 30, 2005 | 03:37 AM
trinydex's Avatar
search... there is a good thread with just about every temp sensor adapter you can buy for your radiator pipe interception.
Old Apr 30, 2005 | 08:13 AM
Oh well thanks for the link.....I guess I should have posted in block letters/underlined that I already did a search.
Old Apr 30, 2005 | 09:52 AM
trinydex's Avatar
i can't recall where it is now... i also did a search but didn't come up with teh thread that i was mentioning... could be from another forum but look on google... i know there are lots of different t adapters.
greddy makes one which is the most popular one used. roadrace engineering carries them.
https://www.evolutionm.net/forums/sh...er+temperature
you might have to call to get the answer you're looking for.
the thread i'm talkin' about started out with this piece...
http://www.steigerperformance.com/PRODUCTS/sp40001.html
at the same time... i'm wondering why you need to know the internal diameter... aren't all the radiator hoses for evos the same... aren't you just gonna buy the samco and hack it up?
Old May 1, 2005 | 12:27 AM
I need to know the internal diameter so that I get the right sized hose adapter. I found a company that sells them in 1 3/8, 1 1/2, and 2 inches. I don't want to get the wrong size.
Old May 1, 2005 | 07:47 AM
timzcat's Avatar
Why don't you just measure the neck where the hose connects on the car. If the stock hose fits, I would hope the Samco is the same inside diameter to fit.
Old May 1, 2005 | 03:22 PM
trinydex's Avatar
or the stock radiator pipe... if anything everything SHOULD be the same size... if it's not you should make it the same size...
TxFAkuma
Aug 9, 2015 08:01 PM
Joehunk
Sep 6, 2011 11:50 AM
TxFAkuma
May 25, 2011 12:05 AM
Methodical4u
42
Nov 27, 2010 01:07 PM
Kracka
Mar 6, 2010 07:23 AM
