Greddy profec b spec 2?
Old May 1, 2005 | 05:43 PM
brandonbigdog's Avatar
Is anyone running the Greddy Profec B Spec 2 in there evo. It says it will work for the evo but is for externally wastegated turbos, Im kinda confused? Any help?
Old May 1, 2005 | 05:47 PM
PVD04's Avatar
I use it in my car. Kind of a pain to get it set correctly, but once it's set up it works great.
-Paul
Old May 1, 2005 | 06:03 PM
ebbeast2005's Avatar
yea i have it with ****ty settings.. After a tune im sure it will be just as good as any other
Old May 1, 2005 | 06:05 PM
djmikeymike's Avatar
read this......... https://www.evolutionm.net/forums/sh...ad.php?t=71416
Old May 1, 2005 | 06:59 PM
03BREvo8's Avatar
it works on bot external and internal.. im thinking about it too.. due to the alky injection
Old May 2, 2005 | 04:55 AM
Evo007's Avatar
I have one and it works great. I don't really find it that hard to set.
Old May 2, 2005 | 06:17 AM
smackdaddy's Avatar
I'm running one with no issues. I have it setup for low boost setting at 15-16psi and on high it cranks it up to 24-25 psi with alcohol inj. I have my alcohol set to come on at 17psi. Also have the greddy remote switching system for the profec installed on my steering wheel. Its fun to gain ~ 100hp with the push of a button. I have it setup this way to conserve alcohol usage. I get about 4-5 tanks of gas per alcohol fill up because I only use it when I really want to.
Old May 2, 2005 | 06:39 AM
Tsurara's Avatar
Quick question... I am boosting just under 1.5bar of boost. Does everyone hit their tuned boost in first? Before I made adjustments I was only hitting .3 bar in first but 1.5bar in everything else... I asked a friend and he said I shouldn't be hitting full boost in first. Is this the case for everyone?
Old May 2, 2005 | 09:17 AM
WHTEVO's Avatar
i am using the spec 2 in my evo also. once you get it set up you will be happy. i haven't had any problems.
Old May 2, 2005 | 09:19 AM
imapunkclaimer's Avatar
i have the spec 2 on my lancer OZ with external wastegate. it kicks ***
Old May 3, 2005 | 12:52 AM
Rcebowl's Avatar
-Paul
I'm looking into getting the Profec II ... so i was just wondering what makes it it a pain to setup?? like wiring? or what?
Old May 3, 2005 | 06:54 AM
VTECH8TR's Avatar
Pretty slick way ot use the Profec B.
Shy
Apr 10, 2010 07:57 PM
21Evo-lution
19
Feb 20, 2010 07:55 PM
Rocket
47
Dec 29, 2009 12:22 AM
PocketAces
Oct 31, 2004 11:16 AM
ThEHiTMaN
Jan 7, 2004 11:12 PM
