Agency Power BOV, need help
Old Jun 14, 2005 | 08:40 PM
madpacket's Avatar
Originally Posted by KazzEvo8
Grrr... anyone installed it OK and have pics?
Trying to install mine and would like to orient it as the stock but the brass nipple for the small vacuum line then points down and the stock line won't reach it ???
What'm I doin' wrong?
Well, before I sent mine back, I took off the four allen bolts on that end with the brass nipple and rotated it 180 degrees, so that the line would then reach it. Of course I still had all the other problems, and returned it.
Someone said that the first batch was defective, dunno if that's true. I never did get mine working right.
Old Jun 14, 2005 | 08:55 PM
KazzEvo8's Avatar
Got more vacuum tubing just now - LAST one in the parts store, the guy was headed for the door to lock it.
Anyway, installed, VERY short test run, packing up all parts and tools in the car in case I have to swap back, no stalling evident yet but that "fluttering" may be happening when it releases pressure.
I have the knob rather near the top of the valve housing and still have no idea whether that means recirc or VTA ...
Headed out again and will be driving around tomorrow. I'll try to see what's up. Worst case I have a great DSM expert to consult. At least it's driveable so far. My stock BOV was leaking at well < 10psi ...
Old Jun 14, 2005 | 10:00 PM
madpacket's Avatar
Oh, didn't you consult the wonderful documentation it came with? Oh, I mean the wonderful documentation on their web site? Oh, yeah, I coulnd't find it either place, and both the seller and the tech answering the phone at agency-power couldn't provide any written instructions.
Sorry for the sarcasm, but I had a pretty rotten experience. I sincerely hope that yours works out better for you.
Regards
Old Jun 15, 2005 | 06:25 PM
KazzEvo8's Avatar
I appreciate your good wishes.
Have tried it today w/the knob almost all the way down and there is a "fluttering" of sorts when lifting off the throttle or coasting and applying light throttle. It sounds like a misfire, really (3" TBE, no cat), in the exhaust. So it must have some effect all the way to the exhaust?
In order to try to get rid of that I got the knob adjusted all the way down. Same issue, if not more distinct. RPM drop from aggressive throttle was a bit harsh.
Adjusted the screw up quite a bit, further from all the way down than my first attempt and this "fluttering" was as distinct but an RMP drop seemed harsher - nearly stalled out.
Now, for all I know, temp and other conditions were different enough through the day that they made a difference in all this half-assed testing. But I thought that with the screw partially up I had better results than with it all the way tightened down or very loose.
Key questions:
Does ANYONE ELSE have this BOV/BPV installed and is happy with it?
WHY is the "first generation" discontinued? Was the flaw in some really a flaw in all but just not everyone complained? What is being "fixed" in the 2nd generation???
Tomorrow I'll put the screw down further closer to where I had it first today and see if I get the more harsh reactions. It doesn't look good, folks. I'll call AP tomorrow for advice and then whom I ordered it from for possible return/replacement for another brand - like the APS I thought I was ordering (yeah, I know, ignorant me)...
Renley
Evo X Dyno Results
27
Jun 15, 2011 03:11 PM
lancer2008
Mar 14, 2011 04:15 PM
Vivid Racing
Dec 21, 2005 11:51 AM
rblader86
May 9, 2004 01:19 PM
