how much boost?
Old May 3, 2005 | 12:50 AM
Rcebowl's Avatar
how much boost?
i was wondering ... on a stock block with just a injen intake system... and a espliser dp and catblack exhuast... what's the max boost i should push?? the fuel system/block/turbo take like 22psi? Safely?
Old May 3, 2005 | 05:45 AM
NOVA EVO's Avatar
If you have 93 in the tank, you can run 22 PSI safely, but that's pretty much as high as you want to go with the stock turbo on pump gas...above that, you get diminishing returns because of hotter air from the turbo...
Old May 3, 2005 | 01:21 PM
Rcebowl's Avatar
word thanx buddy
Old May 3, 2005 | 04:18 PM
EvoPanda7's Avatar
if i run at 22psi... what are some good mods to make so i dont over heat my motor? (plz no one say intake)
Old May 3, 2005 | 04:21 PM
theblue's Avatar
if you don't have headstuds then 21 MAX. if you're not reflashed or tuned then you'll do damage because of inccorect fuel even at 21.
fabiano
22
Jul 21, 2016 09:38 AM
JGNERAEVO9
23
Mar 7, 2014 07:14 PM
Shastamiknasta
21
Jun 30, 2013 10:15 AM
dxbtune
53
Oct 11, 2009 08:16 AM
jmlsevo8
May 14, 2008 08:13 AM
