How do various types of diffs affect AWD performance..
Old Feb 14, 2003 | 10:03 AM
  #46
MrAWD's Avatar
Last one, I promise...
Originally posted by Ben
You'll agree that the wheel with traction is getting all the torque right? I meen if the diff is locked, and the one wheel has no traction, then more torque will go to the wheel with traction. Well, power is a function of torque. Thus more power will be used by the wheel with traction. It's as simple as that. You're still looking at it as the diff locking, which makes equal speeds and thus equal power. Well it doesn't work like that if one side has little or no traction.
OK, this is my last try. Ben's cup is way too full to let anything in, so this might be a waste, but let's try it anyway!
You are confused between the torque/power that gets delivered thought the diffs, versa the torque/power that actually moves the car. Those are two different things and shouldn't be taken as same!
If the wheels are at the full lock as you said, power/torque goes on both side equally. This is just pure mechanics and anything else is just not possible. What will happen with that power when it gets to be delivered to the ground is a different thing. If one side is in the air, it will be spinning freely with all of the torque/power that is sent there. The other side has maximum traction and it will actually move the car. And YES all of the torque/power will be delivered through that side, but that doesn't mean that other side doesn't get any torque/power. It is just not used at the moment, but it is delivered through the both locked axles, and exist everywhere. It is just not used at the moment!
I'm only repeating what I've said before, so if you don't understand by now then I guess there is no hope.
If you empty your cup first, there might be some...
Maybe I'll go have that
I have to agree, this always helps!!
Fedja
Old Feb 14, 2003 | 10:07 AM
  #47
chronohunter's Avatar
Originally posted by MrAWD
Is there a way for you to try to explain this part a bit more?
Basically, you are saying that car will oversteer more. Would that be because front end gets to put more power down and that rotates the car and increase the oversteer.
Or, due to the increased front grip, rear end (mainly due to the lover weight) now loses its traction even quicker than before and rotates the car closer to the RWD style as you said.
Which one of these two makes mores sense. Or maybe they are both right?
Any extra info would be appreciated!
Thanks
Fedja
The extra power that the diff will get to the outside front tire will rotate the car quicker (creates a "yaw moment" around the polar axis)
As far as what the .5 means in a 1.5 way diff it just refers to % of lock... A one way has no lock on decel, a 1.5 way has 50% lock on decel and a 2way is 100% locked on decel. All are locked on accel. Fromwhat I understand the amount of lock can be changed by changing the preload on the clutch packs. I'm not sure if it can be done independently for accel and decel. Generally the more lock on decel the more the car will resist turning (= understeer)
Off course as discussed many times before (but it never gets old!) all of these combinations are avaliable so we can tune the balance of the car into the corner (and on a variety of surfaces)
Old Feb 14, 2003 | 02:27 PM
  #48
evo_dan's Avatar
I thought this would make the car understeer if applying power to the outside front tire at the treshold of grip in a corner. This is what was leading me to believe why the open dif at the front might be advantageous in exiting the corner at wide open throttle. I figured the open dif doesn't put at much power down in the front outside wheel allowing for steering through and out of the corner, while the 1.5 rear LSD dif gets more power down, making the car act more as a RWD.
This was the theory I came up with from reading these past posts. Now I think I'm starting to get confused again. Am I out to lunch here?
(I also like to add that my theory included the open dif causing understeer at corner entry, but not through the corner.)
Old Feb 14, 2003 | 03:00 PM
  #49
MrAWD's Avatar
When I read it first time, I tough that he was saying (actually that is how I was reading it) that power goes to the inside wheel and creates yaw momentum that helps rotation of the car. But, I agree with you here evo_dan about that extra power on the outside wheel that is at the grip treshold, that will make things worse (push wise).
Also posted by evo_dan
This one I don't get. Care to explain how would an open diff cause this?
Thanks
Fedja
Old Feb 14, 2003 | 03:15 PM
  #50
the real variables are how fast is the corner (faster=less understeer) and how much throttle is give (and how much power the vehicle has). If extra drive torque is applied to the outside front (or rear) it will pull the car around. it's a fine line though because if too much throttle will overwelm the tire causing understeer (as you stated) and if the rear end is doing the same thing and the driver is carefully feeding the throttle on the way out the car will almost steer itself out of the corner! Just imagine the car from above with a pole through the forward part of the roof and now imagine power going mainly to the outside wheels and what the car would do (even if the wheels were straight! can you say torque steer!). Because the car is in real life leaning in the corner (lateral load transfer) the outside tires have more grip so even a car with a lsd that can only lock the car will still steer because the outside tires can put more power down due to the extra load they have in the corner
Just the opposite... The car as it enters the turn needs the drivetrain to be as free as possible so each tire is able to find the propper wheel speed for it's particular radius (remember each tire has a different radius to follow). So the open diff in the front helps get the car into the corner... but so would a 1-way diff (which only locks on power and provides the benifits listed above)
In the center we want some locking because we ould like the rear "axle" to provide a little drag to help rotate the rear.
As stated in previous posts we want the vehicle to make an efficient transision from braking to cornering meaning we will have to blead less speed off to get into the corner (we can brake less and later) then carry this extra speed through the corner (high apex speed) and then use it to get the maximum exit. Balance and grip for the first third of the corner (where most of the turning should be done on most corners) then balance and good drive out
Hope this helps and dosen't just make tings worse
Old Feb 14, 2003 | 03:30 PM
  #53
MrAWD's Avatar
Originally posted by Claudius
Anything for you, Fedja
I hope that V-day is not affecting you that much!!
Thanks!!
Fedja
Old Feb 14, 2003 | 03:34 PM
  #54
Hey you're the one that is quoted as saying "mainly due to the LOVER weight"! You guys want to tell us something?
Old Feb 14, 2003 | 05:44 PM
  #56
just got back from dinner with the GIRLfriend very nice although it cost me $10 in flowers LOL
Just be happy you aint getting AYC and that you are getting the cars soon! I'll come and test drive yours (order some tires ) hehehe
Glad to hear about the girlfriend though Mr.AWD will probably be devistated
Anytime you want to come over you just let me know. I can run at my local track for $60. We'll have to work on the tire thing
Old Feb 14, 2003 | 06:06 PM
  #58
Let me edit that then
$60 sounds good. Is that for a whole day?
I'll get a set of tires, you'll get the gas and oil change afterwards. But I'm not sure you'll be better off! j/k I get 7 mpg on track...
To all of that...you've got a big heart Damn, I'm doing it now
P.S. $60 is for a half day but it sounds like it will save me a lot of gas money
Old Feb 22, 2003 | 02:26 AM
  #59
FresnoKaliRacer's Avatar
Whao.. what a mindful!
Had to stick in some ear plugs to keep it all from comming out!
Althought not involved in the event.. thanks for the info all! Very informational!!
Cheers
Jay
kyoo
1244
Jul 27, 2022 01:02 PM
MurtazaDSM
Dec 17, 2016 11:05 AM
nudge120
Jul 6, 2015 12:53 PM
EVOlutionary
67
May 15, 2007 03:25 PM
wtz
71
Jul 2, 2004 01:11 PM
