Is Fuel upgrade necessary?
Old May 12, 2005 | 09:53 AM
scherejs's Avatar
Originally Posted by Evo007
The stock fuel pump is more than enough for what your doing. No need to waste the money!
replacing the stocker is never a waste of money. get the pump and flash like said earlier.
Old May 12, 2005 | 09:59 AM
blitz118's Avatar
When is replacing the stock fuel pressure regulator necessary?
Old May 12, 2005 | 10:05 AM
Nez136's Avatar
ok, i ordered a Walbro yesterday and a FPR, i will be installing it all this weekeend after the car is broken in
Old May 12, 2005 | 10:25 AM
Volunteer's Avatar
Originally Posted by timzcat
I am suprised to hear you say that. It appears that the Walbro on the stock regulator is pushing 52 psi of pressure with no hose attached. The pump is too much for the stock regulator and is overrunning it.
I ordered a new pump because my stocker is starving for fuel at WOT. I will add the regulator for the flexability what PSI should I be running with cams, and full exaust?
Old May 12, 2005 | 10:57 AM
timzcat's Avatar
With the vacuum hose off the standard is 42 to 45 psi.
Injector manifacturers typically use 43.5 psi when flowing the injectors for size and pattern, so right around there is best.
At 52 psi or so with a Walbro and no pump you have no real control over fuel flow at idle or light cruise and the car will run richer then normal.
Old May 12, 2005 | 11:01 AM
Volunteer's Avatar
Thanks.
Frasch
Oct 13, 2016 08:22 AM
evopowned
E85 / Ethanol
49
Apr 20, 2011 09:51 AM
Warrtalon
85
Nov 5, 2005 07:52 AM
BJai02
16
Jul 19, 2005 08:31 PM
rt turbo
Aug 30, 2004 07:01 PM
