safe boost with my fuel setup.
Old Aug 30, 2004 | 05:52 PM
rt turbo's Avatar
im tuning my newly installed fuel setup. it consist of, 225 fuel pump, braided an-06 fuel lines. perrin fuel rail, 880cc injectors, aeromotive fpr (43psi press.). im currecntly tuning with the emanage... today i ran 21 psi peak boost with a -23 correlation at the lowest one the emanage. my afr is 10.3-9.7 (obviously too rich). but im getting great power at this tune. tonight, im ganna go to 11.0, which seems as of now it will be around -30 or less corr. what psi can i run on 93 and stock head bolts to keep it somewhat conservative? would you all recomend installing my studs soon? im ganna do the nocam removal head stud install... is this recomended?
p.s. anyone understand how to use to injector duty on the emanage?
Old Aug 30, 2004 | 07:01 PM
rt turbo's Avatar
bump, anyone... 17 post, no replies?
phil_
Lancer Engine Tech
11
Jan 11, 2006 10:14 PM
Ozturbo
Lancer Aftermarket Forced Induction Tech
12
Mar 29, 2005 09:44 PM
rt turbo
14
Feb 13, 2005 03:42 PM
rt turbo
16
Oct 3, 2004 08:53 PM
rt turbo
Jan 23, 2003 09:13 AM
