My car just "QUIT" so did the A/C
was auto Xing and car came in and just "Quit" clutch to floor turned key- NOTHING lights on but nothing happening under the hood. would run fine with a push start.
here is what happened:
1. The launches at the start caused a wire to dislodge on the starter
2. The A/C connector came loose same way with harder than usual launches.
If this happens to you, dont panic, just look under the car for the wires that came loose re-connect them!!!!!
No, once the connectors were reattached, problem gone!! they just came loose. Had Mitshu evo mechanic look at it, he was actually at the car show/autoX event, so he saw it when it happened.
Originally Posted by 11secEVO7
this happened to me while circuiting...
but eventually found out that my crank angle sensor was messed up
will have them look at that also.
Hehe that happend to me while installing my bushcur lower intercooler pipe. I was installing the turbo inlet pipe and the wire came loose off the starter. Took me 1 hour to figure out the problem. I checked every god damn fuse and wiring. I was having a panic attack. Lol then I saw it was the wire.
kd5byb
Lancer Troubleshooting
Sep 7, 2013 05:44 AM
