anybody know why my car is like this?
Old May 16, 2005 | 04:11 PM
SuperchargedGTZ's Avatar
what plugs...i had the same problem under WOT. i just changed the plugs and the problem was gone
Old May 16, 2005 | 04:14 PM
WannaRace's Avatar
This isn't the infamous two little plastic clips coming off the intake snorkel is it? Check that out to be sure. It's a simple fix...
Old May 16, 2005 | 04:19 PM
Thegame's Avatar
Your may have hit fuel cut or even limp home mode or something. But without a CEL I'm not sure. Reset the ECU again.
Old May 17, 2005 | 01:15 PM
kayyoevo8's Avatar
it sounds as if it is backfiring and making popping noises from the exhaust. anyways the codes it threw were P0420, P0138, P0234, P0113, P0107, P0234.
Old May 17, 2005 | 04:00 PM
kayyoevo8's Avatar
i still have the stock plug wires, but i have the iridium spark plugs. i tried to replace it with the stock plugs, but it still happens. no i did not hit fuel cut. i know how it feels. do i need to change my plug wires? also, how do i make my greddy type s bov not flutter?.. i have it recirculated and it still flutters... sounds nasty..
Old May 17, 2005 | 04:07 PM
sr20det91's Avatar
Thatas alot of codes.
I'd start by putting the stock BOV back on just to see if it still does it. Running 18PSI the stocker is fine. Minus the ricey whoosh sound.
Old May 17, 2005 | 04:33 PM
kayyoevo8's Avatar
i tried the stocker on, but it is still making weird popping noises from the exhaust and losing performance. first you hear the popping noise, and then the choking starts happening.
Old May 17, 2005 | 05:09 PM
kayyoevo8's Avatar
What does these codes mean anyways?....
DTC P0113: Intake Air Temperature Circuit High Input
DTC P0107: Barometric Pressure Circuit Low Input
DTC P0234: Turbocharger Wastegate System Malfunction
DTC P0420: Catalyst Efficiency Below Threshold
Old May 17, 2005 | 05:23 PM
2faast4u's Avatar
this happens to me too. only it happens to my 87 corolla and because it has no exhaust(sounds like an animal) since it rusted away awhile ago, too bad it would prob run the 1/4 in 36 something(no joke).... sorry i cant be any help, good luck!
Old May 17, 2005 | 06:26 PM
Jonasan50's Avatar
I had the EXACT same mileage when mine started doing that.. You run the car at high boost pressures for a while, the plugs wil "crack" per se.. I changed them out with new OEM Mits plugs and it was corrected.. The old plugs might look ok, but they've given up.. Since the change, I put 5K more miles running like a banshee.. Buy NEW plugs and try that.. It happened with all my DSM's, and worked the same way... My .02...
Old May 18, 2005 | 05:06 PM
wheming's Avatar
damn, that's alot of codes!
Good to know someone has had the exact same problem.
Please let us know after you put new plugs if that fixes it.
Old May 18, 2005 | 08:32 PM
kayyoevo8's Avatar
i guess i will have to try new plugs then.. i'll update on how it goes.
Slimdatwelve209
Sep 12, 2019 04:35 PM
Devesh Budhram
Dec 30, 2016 03:21 PM
Ralli_Red
15
Mar 2, 2016 09:59 AM
littlegif1
Jun 6, 2015 07:20 PM
nightrider
Lancer Troubleshooting
15
Sep 10, 2002 01:06 AM
