buschur cat leak
Old May 13, 2005 | 10:45 PM
ibanez_926's Avatar
buschur cat leak
I just installed buschur tbe, Installed beautifully btw, top quality everything but one question the high flow cat at the downpipe connection has a small leak, its not bad but i can still feel it on my hand, just wondering why there isnt a gasket for it so there is no leaks, and is a small leak signifacant
Thx
Old May 14, 2005 | 07:13 AM
Hiboost's Avatar
I think the directions that it came with mention that you don't need gaskets and that any leaks would be minor. You could try sanding both surfaces with a sandling block or grab a 3" gasket from an auto parts store or even a place that sells truck parts. Hope that helps.
Old May 14, 2005 | 12:36 PM
03BREvo8's Avatar
Didnt you get the 3" c clamps when you got the exhaust.. there shouldnt bee any leaks . you are talking about the 3" highflow cat right?
Old May 14, 2005 | 04:31 PM
ibanez_926's Avatar
eh
i guess i will just go buy my own gasket, i just dont understand why buschur dont supply one
Old May 14, 2005 | 04:34 PM
Rez90's Avatar
i could be wrong but i think that buschur changed their exaust design to using flanges..... not sure though
Old May 14, 2005 | 08:24 PM
03BREvo8's Avatar
I bought mine in july and i dont think they have changed it? if you look at the pics on they're site there arent any flanges.. did you buy it from Buschur or someone else... if its got flanges its not a buschur... ... the 3" c clamps come with addhesive on them to seal the pipes... no gaskets needed...
Old May 14, 2005 | 08:34 PM
03BREvo8's Avatar
here look http://www.buschurracing.com
Old May 14, 2005 | 08:56 PM
GREDDY's Avatar
Thx
I remember David saying he can build with flanges now per request. So did you get the slip fit or the flanges? Did you buy it new from Buschur? If you bought it used, just order new clamps.
Old Jun 12, 2005 | 08:39 PM
BoostWhore's Avatar
Just installed mine and i have a leak. I found a 3 in 2 bolt gasket and it fit in there, i possibly think it may possibly be leaking at the dp and 02 housing. I think there needs to be sometype of gasket there...
Old Jun 13, 2005 | 07:27 AM
juyanith's Avatar
I believe they did change the design to use a flange between the downpipe and cat/test pipe. You can see it in the pictures on their website. Unfortunately, I have the older slip-fit version so I can't tell you if it comes with a gasket or not, but I'm sure they can help you out if you give them a call.
Old Jun 13, 2005 | 07:31 AM
jerdeitzel's Avatar
I've got the buschur 2.5 downpipe and didn't use a gasket for the o2 housing. it works great. I pondered why there wasn't one for a while. but if you look at the housing im not really sure you would even get a gasket to work right.
Old Jun 15, 2005 | 02:12 PM
BoostWhore's Avatar
i have the same problem and they dont want to do anything to help me out. I found a gasket after they told me there wasnt one b/ its a special flange. All I know is they pissed me off and sent some wrong bolts to assemble the ****
Old Jun 15, 2005 | 07:18 PM
vee21's Avatar
I have a Buschur TBE system installed on my car I put in on in April. It is flanged between the downpipe and the cat/test pipe section. I didn't request the it flanged it just came that way. How major of a leak is it? Are you getting carbon buildup on the flanges? I have not had any problems with leaks. As far as the downpipe leaking I know this is a dumb question but did you take the dounut off of the O2 housing before you put on the downpipe?
Old Jun 18, 2005 | 10:21 PM
David Buschur's Avatar
If you found a 3" gasket that fits boost ***** I'd appreciate it if you'd let me know where and the part number. We have continued to search and have found nothing. Also have had a prototype copper gasket cut that doesn't work worth a crap.
Also if we sent you wrong bolts then I am sure had you called we would have sent the right ones to you ASAP.
David Buschur
OnAll4's
15
Jul 2, 2020 04:55 PM
ProPilot04
14
Oct 5, 2015 02:47 PM
yikez
74
Jan 22, 2011 09:33 PM
scottatyamaha
Aug 23, 2006 05:10 AM
Bitnode
Lancer Troubleshooting
Sep 3, 2003 05:49 PM
