injector duty - AFR
Old May 25, 2005 | 06:59 PM
SlowCar's Avatar
injector duty - AFR
Does any one know how much decrease in injector duty % would one see for an increase in 1.0AFR on stock 550 injectors + upgraded walbro fuel pump @~20psi boost?
Old May 25, 2005 | 08:21 PM
nothere's Avatar
maybe your question needs to be clearer, are you deciding on larger injectors ? Or are you trying to tune without a wideband? What duty cycle do you have now? Are you going from 12 to 13 or 10.5 to 11.5?
do you have a tune-able ecu or stock?
Old May 25, 2005 | 08:53 PM
SlowCar's Avatar
I'm deciding if I should go w/ the 660s. I got a flash from Al and I'm thinking of utec/WI. Thinking from ~10.5 to ~11.5.....
Old May 25, 2005 | 09:08 PM
nothere's Avatar
I do not think you will need bigger injectors.
your thinking is correct, with WI you can trim the fuel a bit.
unless you are going for a bigger turbo, but in that case just wait to view your own logs (if you get the utec tuner)
as an example, at 18 lbs boost and WI, I never saw anything over about 73% duty cycle. That was a bit leaner AFR than you plan. you should be good up to 80% before you go to bigger injectors, no?
Old May 26, 2005 | 06:39 AM
Ted B's Avatar
You do not need larger injectors.
Old May 26, 2005 | 08:10 PM
SlowCar's Avatar
Thx guys, saved me ~$400!
Eddis
Nov 4, 2013 05:03 PM
Eddis
Oct 15, 2013 08:38 PM
acssa
Dec 3, 2011 12:36 PM
94AWDcoupe
Apr 30, 2009 03:38 PM
Dus10
Oct 1, 2006 05:21 AM
