help car is not right
Old May 29, 2005 | 09:03 PM
scherejs's Avatar
took cams out today and replaced lifters. also added walbro fuel pump. got it all back together and everything seemed to run fine. after about a half hour driving the car took a nose dive and wouldn't boost. had to putt 15 miles home. as soon as it started boosting it would nose dive. it feels like an intercooler pipe came loose but i checked everything and it is fine. any ideas?
Old May 29, 2005 | 09:15 PM
taylor's Avatar
Just a guess, but perhaps the pump is bad. It's probably one of the parts you installed, and the lifters won't cause that.
Old May 29, 2005 | 09:18 PM
scherejs's Avatar
you think the pump would go bad that soon?
Old May 29, 2005 | 09:53 PM
scherejs's Avatar
also just noticed a cel. i'll get it read tomorrow.
Old May 29, 2005 | 10:01 PM
bigjhoney's Avatar
Get the code checked ( autozone pulls it free). Might be something silly, and just putting the car in limp home mode. Did you retune the afc for the cams? Bleed the lifters? If you did all the that, unplug the battery and let the ecu reset. Drive the car calmly for a few miles and see if it still does it.
Old May 29, 2005 | 11:04 PM
QAT-R's Avatar
If the boost spikes up then nose dives your probably hitting boost cut; check the connections on the boost soleniod and actuator.
Although, I have a feeling that might not be the case.
Old May 30, 2005 | 03:54 AM
scherejs's Avatar
no it won't even boost at all. as soon as it hits 0 to 1psi on boost gauge it sputters.
Old May 30, 2005 | 06:10 AM
use2vtec's Avatar
My guess is that a connector came loose. Recheck all connections and check your cam timing. From what you are saying I dont think its the cam timing but its better to check it out and know for sure.
Old May 30, 2005 | 10:12 AM
scherejs's Avatar
ok well i can't pull the code cuz it won't stay running. so i can't make it to autozone. i double checked the timing marks on the gears relative to the valve cover and it's still fine.
Old May 30, 2005 | 10:17 AM
redevo561's Avatar
check the rubber connections on the piping it could of torn or has a hole you wont be able to see it
Old May 30, 2005 | 10:39 AM
scherejs's Avatar
checked all hoses and everything is fine. it finally started but idles bad and sputs. everytime i try to give a little throttle it acts like its out of gas and sputs.
Old May 30, 2005 | 11:05 AM
scherejs's Avatar
took the valve cover off and everything looks ok there too.
Old May 30, 2005 | 11:16 AM
dsmythe2's Avatar
air in the fuel line/vapor lock?
Old May 30, 2005 | 01:24 PM
scherejs's Avatar
how would i check this? and how to cure it?
Old May 30, 2005 | 01:39 PM
scherejs's Avatar
got it started and it's idling really rough. sounds like i've got huge cams in it or something. could this be a timing issue with the balance belt or something?
