ıncrease 400-450 hp?
Originally Posted by ct9a gsr
That was my car, not Al's... his car has much more power. However, he did tune my car to get those results. That was also with 272/272's and a cusco chromoly steel flywheel... not 264's and stock flywheel.
You have a dyno chart of your 400whp by any chance? =]
To the orginal poster of this thread, 450 crank hp is achievable easily on stock turbo... Buschur Stage 4 + methanol and a good tune will get you there. If you use a 17% drivetrain loss, I'm making 469bhp / 506btq with this setup.
all i have is megan racing turbo back, hallman boostcontroller at 21 psi. and a www.jestrtuning.com M1 flash. the flash alone gave me a big gain, big isnt the word HUGE. John knows what he is doing. this was on a hot day, 92 f to be exact and i was on 93 octane pump gas. 400whp is very easy to obtain without all of that extra money.
aps, you will need:
- Full 3" exhaust with test pipe
- HKS 272 cams or better
- adjustable cam gears
- bigger IC
- Engine management system (UTEC/AEM/XEDE will work fine)
- and above all: A GOOD TUNE
I'm guessing that 98 Octane in Turkey is a RON rated gas, which would roughly equate to 93 (RON+MON)/2 in the US. On a US 93 Octane tune with the above mods, you should be able to clear 400 crank hp. I was at a similar level (didn't have the test pipe or IC) and I ended up at approximately 380 crank hp. You may want to add a wideband O2 meter such as the Innovate LM-1 to make sure your tune is safe (I wouldn't go above 11.5 afr). Also, you should not need bigger injectors, but it won't hurt to get 660s or 680s if you plan on upgrading to a white rabbit turbo in the future.
l8r)
- bigger IC
l8r)
Originally Posted by rlazer5000
How do you guys feel about the ATP 3071R kit? Is it possible to gain 400+ WHP on pump gas (93)? I don't really wanna shell out $4K+ for an AMS kit if i don't have to!
l8r)
Valerie Strong
Mitsubishi TC-SST Discussion
Oct 20, 2016 08:55 AM
