Atp turbo kit owners
Originally Posted by trinydex
even on race gas maps? iunno shrugs... if you're gonna run mor ehtan 30psi... you should look into 1000cc. plus... it don't hurt.
Originally Posted by unknown2
What fuel are you using and how are your #s also for power.
Originally Posted by jj_008
I run 100oct for those 30psi runs. I made about 70whp more then cars w/ cams on pump and I only made 70whp more then cars w/ cams on 100oct at only 26 psi. At the time, I could only reach 26 psi due to having the wrong wastegate spring. At 30psi, I probably make 100whp more then cars w/cams on 100oct.
Originally Posted by IE Evo
JJ008 your trapspeeds say otherwise in regards to your power level. I feel running 30 psi is hurting your power but I could be wrong. But I am positive your car is not making the big power u think it is or the big power it should be making. Your low stocktubo like trapspeeds support my hypothesis. I hope u figure it out.U seem like a cool guy and I wish u the best.
Soon everything is going to change.
Its the stock I/C on a 90 degree day that is hurting me. On the dyno, when it is 65 degress w/ 3 huge fans, I threw down some good numbers. Unfortunately, when it gets over 80 degrees my car feels like a slug. So at the track on a hot day, my turbo is probably turning 35psi just to make 30psi in the intake. Which means it is blowing even more hot air since the turbo is out of its effiency range. Plus, sitting in a staging lane idling doesn't help either.
I am worried about using this caliber of a turbo with a stock manifold. Should I port it? Should get get that Megan Racing twin scroll one for only $299 or so? That may actually be the answer and just port the 02.
