EVO VIII final drive ratio?
Does anyone know the rear end (front should be the same) ratio in the EVO?
Example: 3.43:1
I searched this site and also googled with no luck.
While I'm here, does anyone know of a factory LSD from a front engine rear drive car with a final drive ratio between 3.10 and 3.50? Must come from an independent rear suspension setup.
To answer the obvious question (why do I need this info?), I am researching for a project.
Thank you.
Example: 3.43:1
Thank you.
4.529 is evo 7.
4.875 is evo 4
4.529 is evo 5
4.583 is evo 9 mr
4.529 is evo 8 rs and gsr
4.529 is evo 8 from 2003 to 2004.
http://*********************/forums/sh...hp?p=80#post80
4.875 is evo 4
4.529 is evo 5
4.583 is evo 9 mr
I know that there are some 4.11 final drives overseas that have been made for previous models not sure on the fitment to the US Evo 8's. Another person to contact would be Jon @ TRE, as they are making a custom final drive that is a 3.83 I believe.
Originally Posted by dohcvtec
I don't think the final drive is in the rear differential, it should be in the tranny. So I guess the real answer to your question is the ratio is 1:1 for the rear diff?
Once mine shows up + installed I'll let everybody know how it is
Jon@teamrip.com
http://www.teamrip.com/Evolution.html
Originally Posted by GEARS
This is true and it works very well. It's going to be a good summer for the EVOs.
Jon@teamrip.com
Jon@teamrip.com
Jon@teamrip.com
Jon@teamrip.com
