Max 4g63 bore???
Old Jun 6, 2005 | 07:50 PM
2s10w4u's Avatar
Max 4g63 bore???
what is the max possible safe bore for the 4g63?
Old Jun 6, 2005 | 07:55 PM
WHTEVO's Avatar
88mm is probably the biggest and safest. good luck.
Old Jun 7, 2005 | 07:29 AM
2s10w4u's Avatar
im from the honda world so i dont know much about the structure of the 4g63 block.
is 88mm still safe for high boost and streetability? does anybody have a picture of a 4g63 bare block?
Old Jun 7, 2005 | 12:02 PM
BlackEVO's Avatar
88mm seems a little large to me. Do you have direct knowledge of that? That would be like a .118" overbore and the most I've ever heard of in a 4G63 is .060" (almost half what you said). only sells 4G63 OEM pistons at .5mm and 1mm oversize, so take that FWIW. I thought the .060" over was a lot when I heard about it, but I would definitely get some second expert opinions on that 88mm
If you want safe and reliable, I would stick with what is safe and reliable: .020"-.040" overbore or a stroker kit if your goal is to add as much displacement as possible.
Old Jun 7, 2005 | 01:09 PM
Kevine326's Avatar
.060" sounds about the highest Ive seen
9:1 0.20" J&E's are nice...
Old Feb 23, 2009 | 12:09 AM
johnhwfd's Avatar
Anybody find out yet?....lol. Its only been4 years.
I may do the .060 due to a blown piston that damaged the block wall. Any input would help.
Old Feb 23, 2009 | 09:03 AM
barneyb's Avatar
There isn't an answer. These are sand castings and they will vary.
Old Feb 23, 2009 | 09:11 AM
Ev0ikon's Avatar
0.040" over is probably pushing it.
Old Feb 23, 2009 | 11:36 AM
1NastyMR's Avatar
most people do .020 over
Old Feb 23, 2009 | 11:58 AM
Erik@MIL.SPEC's Avatar
Mitsubishi recommends no more than a .040 overbore (86mm). I have head people say you can push things to .080 (87mm), but certain compromises come with that.
Old Feb 23, 2009 | 12:08 PM
deanner's Avatar
86mm should be the max you can overbore,I have over bored to .060 though,but thats pushin it!
Old Feb 24, 2009 | 06:16 AM
GregGSC's Avatar
86 is about it on anything with 800 or less.
If its a 400hp rebuild maybe 86.5
if your shooting for the 1k plus stick to 85 or switch to a 64 block.
Old Jun 25, 2009 | 12:53 PM
evo_glasses's Avatar
Well, if anyone has does do a .060 over let me know. I am a cheap bastard and have 4G64 wisecos and don't want to spend money on new 4G63 pistons... My 64 block is pretty much shot and has been sitting too long. Since I got a 63 might as well make a stroker huh?
Old Jun 26, 2009 | 09:17 AM
FX11's Avatar
Old Jun 26, 2009 | 11:29 AM
BLKCarbonEVO's Avatar
I agree with most others... 86mm will be the max for a well tuned daily with mild-high hp
maxroach
Jun 15, 2017 02:50 PM
Howulikemyevo
For Sale - Part Outs
Dec 13, 2016 05:41 AM
Howulikemyevo
15
Dec 13, 2016 05:40 AM
bertune
16
Feb 4, 2010 07:11 PM
FastMD4G63Drive
14
Sep 30, 2008 07:26 AM
