GT35R Turbo?
Old Jun 11, 2005 | 12:45 AM
Evoisdream's Avatar
hrmmmm where do u guys reccomend getting a turbo and does anyone know what AMS'S setup is ?
Old Jun 11, 2005 | 03:29 AM
MR's Avatar
MR
if u merge a 2.3L stroker with a GT35r .63AR, will this setup be gd?
Old Jun 11, 2005 | 04:14 AM
11secEVO7's Avatar
^ well if u got the stroker i'd recommend going with the 0.82a/r ...since u'd be able to spool it without much lag due to the increase in displacement
Old Jun 11, 2005 | 04:17 AM
MR's Avatar
MR
rational behind the 0.82AR is that u get better top end power?
i was tinking of 0.63AR for much better spool up, does this thinking of mine equates?
pls advise...
Old Jun 11, 2005 | 04:30 AM
WrX Kila's Avatar
pls advise...
Yep with an .82 ar you will get better top end. You will spool up about 500rpm later. On a .63 you will get better spool up and give up some top end. You have to know what you want.
Old Jun 11, 2005 | 05:41 AM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
Originally Posted by jj_008
.70 A/R comperssor housing is the only one you should get. 4" ported shroud would be an added bonus and is highly recommended. A .60 A/R compressor housing would probably surge like crazy.
He is exactly right....additionally if you get the gt35r make sure that it has the 4" ported shroud......70 a/r . If you sway away from this setup you will likely have surge pretty bad if you start to build boost from a lower rpm in say 3rd , 4th or 5th. I made that mistake and ended up having to get a ported housing later. CAll up precision turbo and ask for patrick. Tell him i sent ya!
Dave
Old Jun 11, 2005 | 09:43 AM
TwStDeVo's Avatar
so is it true that people should stay away from the gt35r at high elevation areas?
Old Jun 11, 2005 | 10:27 AM
Evoisdream's Avatar
nah the gt35R is fine most are running 30R but thier is such a minimal difference between the 2 and u get so much more power out of the 35R thier is no reason not 2 if u search a bit thier are a ton of threads about this....
so dave u think a precision turbo .70ar and 4" compres housing and ill b money?
Old Jun 11, 2005 | 04:04 PM
Evoisdream's Avatar
680 GT-35R 82mm 56 0.70 Ball Bearing 68mm 84 0.82, 1.06
thats what i found on Garrets site? is that the one im looking for other then the 4" compressor housing?
Old Jun 12, 2005 | 12:41 AM
Evoisdream's Avatar
Gooooo
Old Jun 13, 2005 | 02:07 AM
EvolutionBoy67's Avatar
how are the ATP GT35R Turbo Kits
Old Jun 13, 2005 | 09:12 AM
Evoisdream's Avatar
i personally dont like them cause i havent herd 2 much great stuff about thier kits and they dont come with a manifold etc...
Old Jun 13, 2005 | 09:36 AM
evodave's Avatar
don't use atp...did you buy the manifold yet ? Yeah that is good turbo to go with ...call up patrick and chat with him but thats what i have. Should be a .63 backside.
Dave
Old Jun 13, 2005 | 10:39 AM
Evoisdream's Avatar
.70 ar .63 backside 4" compressor housing
Old Jun 13, 2005 | 01:43 PM
KasEVO8's Avatar
atp has good turbos etc. but i wouldn't use there atp kit for the evo. But overall there a excellent company.
