only 16 psi?
Old Jun 12, 2005 | 10:25 PM
REDEVO951's Avatar
only 16 psi?
ok i just installed my autometer boost gauge and it idils at 20 vac but it spikes at 16 psi boost and then settles down to 12 psi boost i know this is not right everything is stock except for a aem intake that the dude i got the evo had installed when he had it mind you this is my first boosted car so take it easy one me guys thanks in advance
Old Jun 12, 2005 | 10:32 PM
Derek Baker's Avatar
he probably had a boost controller in it before and returned it back to stock, leaving out the stock boost line with the pill in it. Thats probably why your only getting 16 psi of boost
Old Jun 12, 2005 | 10:39 PM
REDEVO951's Avatar
no my friend did not work on the engine at all just the intake that a shop installed and it seams to run real rich black soot on the bumper edges after a few days of driving hard but my best 1/8 mile was a 8.98 i know it can be better
Old Jun 12, 2005 | 10:46 PM
bluebanana23's Avatar
get a flash to take care of the rich issue and to tune the intake
Old Jun 12, 2005 | 10:51 PM
REDEVO951's Avatar
where can i get that done i live in riverside ca i go to orange county a lot also how much does one cost? thanks
Old Jun 13, 2005 | 01:08 AM
TrojanMan's Avatar
probably a closer shop near you, but here's one in torrance (they specialize in WRX, STi, and EVO):
http://www.harmanmotive.com/
riverside to torrance is about 45-60 minute drive
Old Jun 13, 2005 | 01:09 AM
vrrrm...psss's Avatar
www.dynoflash.com
Old Jun 13, 2005 | 01:14 AM
turbolarry's Avatar
Right around the corner in Colton;
http://www.tuningtechnologies.com/
Old Jun 13, 2005 | 11:36 AM
REDEVO951's Avatar
Cool Thanks I Will Be Going To The Colton Shop Soon How Long Does It Take To Do A Flash?
Old Jun 13, 2005 | 11:41 AM
scott88vr6's Avatar
I would check to see if the gauge is off.
Old Jun 13, 2005 | 11:44 AM
REDEVO951's Avatar
Can I Rig It Up To My Air Tank At Home And Test It Like That?
Old Jun 13, 2005 | 01:31 PM
DaWorstPlaya's Avatar
Is it connected to the correct line? also as Scott88vr6 said, your gauge may be off .... Also EVOs run rich stock ....
Old Jun 14, 2005 | 11:49 AM
donour's Avatar
I second this one. My autometer guage reads about 1 psi high all across the range. It has since day one. Yours might be reading 2-3 psi low. If you tested it on a hot day, then you were getting 19psi tapering to 15-16 psi which is normal.
While off, does the gauge zero correctly?
d
bboy_RES
32
Jun 18, 2009 02:26 PM
kimletrim
23
Oct 10, 2006 06:32 PM
li1p1aya
Jan 30, 2006 10:49 AM
El Boricua
10
Mar 29, 2005 05:01 PM
19psi
67
Jul 23, 2003 10:59 PM
