compression test
Old Jun 13, 2005 | 02:20 AM
TrojanMan's Avatar
compression test
anyone ever perform a compression test on their evo? how does one go about doing this? i actually had one done already and everything was fine but i was just curious how it works? what part of the engine do you read the compression from and how? do you go through one of the spark plug ports or something?
thx in advance.. and yes, i'm a newb
Old Jun 13, 2005 | 02:27 AM
EVO7's Avatar
basically you stick a tire pressure gauge in your exhaust pipe and rev the car to 9000 rpm, so you will have to disable your rev limiter to do it... you want to get about 40psi or your bearing are shot...
JK, okay basically all you do is remove the spark plugs put the special compression guage into the hole were the spark plug went, it will thread in, and crank the engine about 3-5 times, this will give you a reading on how much compression is in that cylinder, then do the same thing to all the other cylinders make sure you have a battery jumper box on the battery becuase since your cranking the engine the more power you take from the battery it could effect the results of the test...
Edit: dont forget to disable the ignitoin so the car doesnt start....
Old Jun 13, 2005 | 03:50 AM
Compjoc's Avatar
disable the fuel injectors too so u don;t dump alot fuel in the cylinders.
Old Jun 13, 2005 | 05:46 AM
GOKOU's Avatar
read below
https://www.evolutionm.net/forums/sh...d.php?t=132827
Old Jun 13, 2005 | 07:23 AM
SlowCar's Avatar
I remember reading somewhere on evom that the cam position sensor plug has to be removed so that the fuel injector will be disabled?
Old Jun 13, 2005 | 01:48 PM
dohcvtec's Avatar
or you could just unplug the injectors.
Old Jun 13, 2005 | 01:58 PM
zyounker's Avatar
Fuel pump fuse till car dies is how ive done it on other cars.. or just find the efi relay.
Old Jun 13, 2005 | 08:33 PM
11secEVO7's Avatar
get a compression tester..they're not expensive
and simple to use
