Need to remove valve cover! What do I need?
Subscribe
Jun 16, 2005 | 08:55 PM
Will I need a new valve cover gasket just to pull the valve cover and check some things out?
Reply 0
Jun 16, 2005 | 08:56 PM
definitely not...go ahead and do it. there will be no problems with pulling the valve cover off...ive seen 3 cam installs...no worries
Reply 0
Jun 16, 2005 | 08:57 PM
Not really, but it is recommended, But i never do. All you need is tools, why are you taking it off?
Reply 0
Jun 16, 2005 | 09:01 PM
Because I need to check my valves, lifters, etc. I had two NGK spark plug electrodes break off and now there is some serious tick. I've checked the cylinders for a light and magnet and found nothing, so either they're in the valves, went through the exhaust, or melted.
However, it sounds like they're still in there somewhere.
Reply 0
Jun 16, 2005 | 10:25 PM
Quote: Because I need to check my valves, lifters, etc. I had two NGK spark plug electrodes break off and now there is some serious tick. I've checked the cylinders for a light and magnet and found nothing, so either they're in the valves, went through the exhaust, or melted.
Holy Sweet Crap Batman!!
Reply 0
Jun 16, 2005 | 10:30 PM
All you need is a 10mm and possibly a 12mm(if you unbolt one of the brackets that holds the throttle cable lin) and you can go to town on that sucker.
Reply 0
Jun 16, 2005 | 10:33 PM
I've pulled my valve cover probably 4-5 times, never replaced the gasket, never leaked. Just watch how tight you torque them back down.
Reply 0
Jun 16, 2005 | 11:00 PM
you NEED this
http://www.evomoto.com/tech_info.php...3_6&tech_id=18
Reply 0
Subscribe
