3 S.M.A.R.T. ways to make more power with more safely
Old Jun 30, 2005 | 11:23 PM
  #136
EvoSam's Avatar
I'm curious. I live up here in WA where we have 92 octane. The base maps on your site are either for 91 or 93, which do you recommend someone like me to use as a starting point for the SMART setup? I personally have a custom tune, but others who don't might want to know too. I imagine it doesn't really matter but who knows without asking....
Thanks,
Sam
Old Jul 1, 2005 | 11:15 AM
  #137
Karash's Avatar
This sounds like a good idea and I am very interested...even though I love my Power FC.
Old Jul 1, 2005 | 04:27 PM
  #138
shiv@vishnu's Avatar
Originally Posted by joeycoates
I feel like I am asking a ton of questions, but I would rather find out this way then the hard way.
4) Get your boost table filled in so that you are seeing your desired boost level/MAF targets. XEDE will log MAF info as well.
5) Activate SMART timing, fuel, boost and let that do its thing.
On number 4 do we have to tell the SMART system how much air flow we want at a certain RPM and it will hold it? And that means that we need to find out what boost number equals x airflow at y RPM? Sence the Ve of any given engine will be different due to its inherent flow characteristics we will have to produce this map and the the SMART system will keep x airflow at y RPM which would equate to a certain amount of boost? These question may be a bit inane, but I just want to understand how it is able to hold a boost # and this is the only way I see right now with what is available. You may know of several different ways for this to work however....
At this point, #4 involves you filling in the boost tables with duty cycles (0-100) until the desired boost (from boost gauge) or MAF (from xede logs) are acheived. The SMART boost feature will simply adjust it up and down according to conditions. We're working on software updates that will allow the user to just punch in boost/MAF targets instead but that is still a little ways off.
Shiv
Old Jul 1, 2005 | 04:36 PM
  #139
Thanks,
Sam
If you are running 92oct, go ahead and run the 93oct map with SMART activated. If it is too aggressive, it will make the necessary realtime adjustments.
Shiv
Old Jul 1, 2005 | 06:36 PM
  #140
Ludikraut's Avatar
Each SMART XEDE should come with a decal that says "Got SMART?"
l8r)
Old Jul 1, 2005 | 06:45 PM
  #141
asasin79's Avatar
Shiv,
will the obd2 reader/scanner automatically clear the codes? what if it is a code other than P0300 and it clears automatically we'd never know of any issues?
vin
Old Jul 1, 2005 | 06:55 PM
  #142
Dustin@Vishnu's Avatar
No it will not. I have tested this a bunch of times. For instance, with the OBD reader in, i pulled the TPS connector, and it tripped the code. The code did not clear until the problem was fixed.
Originally Posted by asasin79
Shiv,
vin
Old Jul 1, 2005 | 07:03 PM
  #143
asasin79's Avatar
thanks dustin.
Old Jul 1, 2005 | 07:29 PM
  #144
S54M3's Avatar
so when can the local install the SMART Xede?? or upgrade to the SMART Xede
Old Jul 1, 2005 | 08:10 PM
  #145
EVOtagger's Avatar
Shiv, I added a c/f lip to my car...you are going to have a fun time pulling it out of dyno4mance
Old Jul 2, 2005 | 10:30 AM
  #146
All of the preorders will be shipped or installed in the order that they were placed.
Old Jul 2, 2005 | 10:40 AM
  #147
S54M3's Avatar
oh, I didn't know u guys have preorder n stuff.. I will call asap
Old Jul 2, 2005 | 01:08 PM
  #148
Look on our main page, you can preorder online.
Old Jul 2, 2005 | 01:12 PM
  #149
EvoTio's Avatar
Dustin, I pre-ordered my S.M.A.R.T. system upgrade several days ago and would like to know If I could do most of the installation myself before I see Shiv at Tuning Technologies? You could PM me if you need to verify my name and ordering info.
Old Jul 2, 2005 | 03:15 PM
  #150
hkfeet's Avatar
Placed my order for smart upgrade! Now someone please buy my wheels so I can get me that rabbit!!!!!!!!!!!!!!!!!!
