Quick Performance Question...
Old Jun 29, 2005 | 07:30 PM
Widebandphillip's Avatar
Got logs to prove the duty cycle?
Old Jun 29, 2005 | 07:36 PM
https://www.evolutionm.net/forums/sh...d.php?t=144045
need we do this again?
Old Jun 29, 2005 | 07:40 PM
gsujeff55's Avatar
im not going to argue with you.....550s are PLENTY to support 400whp
Old Jun 29, 2005 | 07:41 PM
What proof do you have? And this had not involve alcohol injection either. Straight up c-16 and all boost.
Old Jun 29, 2005 | 07:47 PM
gsujeff55's Avatar
Well, i have alcohol injection, so i know i don't need them.....but what proof do you need? I don't have any logs to show you anything...but ive been running stock injectors and lots of boost for quite a while with zero knock. Consistant 116mph traps with no knock on a race gas mix, not even strait c16(this was without the alky, i just installed that).
but, you have your way of thinking...i have mine. If you think they aren't enough, so be it....i think they are.
Old Jun 29, 2005 | 07:56 PM
RREvo's Avatar
I have a offtopic question how is the idle with your 264/272 combo ?
See, alcohol injection IS a fuel. You actually take out fuel when spraying alcohol so that doesn't count. That'll actually lower the duty cylcle as opposed to running straight boost with no other power adder. Again, race gas is an oxygenated fuel. IF you ran race gas, you'd know that the afr ran richer than it would have been running straight pump. Therefore you'd have to take out some fuel and run less duty cycle.
Old Jun 29, 2005 | 08:03 PM
Oh..and c-16 won't be knock prone to regular 93 because of the lead inside the gas and the result of a higher octane, but that doesn't mean it's ok to run stock injectors because you weren't knocking.
Old Jun 29, 2005 | 08:56 PM
gsujeff55's Avatar
well, its ok in my book.....
if im not knocking, im atleast getting enough fuel.....just because the injectors are at 95% duty cycle doesn't mean they won't get the job done....its just a safety precaution i guess.
i know alky brings down the duty cycle, thats why i said that i KNOW i didn't need injectors....but i don't think anyone else has to have them either....but thats just how i feel
and my idle is lopey but thats because i have my cam gears set at -3,-3 for the midrange punch.....with a -4,-1 setting...the idle will be stockish
Old Jun 29, 2005 | 09:00 PM
RREvo's Avatar
I am asking because I just installed the 272/272 and is lopey but stable no staling or anything like that .
Old Jun 29, 2005 | 09:09 PM
Fair enough. I can't change the way people think. I can only give advice.
Old Jun 29, 2005 | 09:23 PM
xLaNcErEvOx's Avatar
lol this 2nd page doesnt even deal with what I asked but go ahead because I already got my questions answered lol
