Greddy RS BOV
Old Jul 7, 2007 | 11:55 PM
Perfect Tool's Avatar
Yes you need to take out the smaller inside spring
Mine wont fit to my Buschur UICP with 1g flange so it has to be welded.
Old Jul 8, 2007 | 08:23 AM
BigBallin's Avatar
You might as well start saving up for a new bov, they do not last long and when you start uping the boost they will leak!! FYI
Old Jul 9, 2007 | 10:34 PM
Isn't the RS good for up to 30 psi?
Old Nov 27, 2007 | 10:47 AM
AUSS1E's Avatar
if you have the old version with a bad diaphragm greddy will fix it to the new version under warranty. Had mine done for free. Just call them and talk to warranty dept
Old Nov 27, 2007 | 12:38 PM
CrackerJackToy's Avatar
HORRIBLE. I bought my car with one on there. The car was having major compressor surge, and even stalled on me a couple times, and that was with it tightened up.
Sold it for a Forge recirculating.
Old Nov 27, 2007 | 09:45 PM
mifesto's Avatar
i like it all around... w/ correct adjustment surge isnt common and holds boost abit better then stock at mid 20's psi
Old Nov 28, 2007 | 10:52 AM
dancarroll0283's Avatar
I was having trouble with mine getting stuck open when on high boost.... I just had to ttighten up the bolt in the center to put more tenson on the spring, and haven't had any problems since.... No need that i know of to modify the BOV works fine
Old Nov 28, 2007 | 11:19 AM
mifesto's Avatar
if it gets stuck open, could also mean u got alot of dirt buildup in there. i opened mine up to do spring mod when i bought it then installed it. after 1000 miles i saw the oil partially dried up already and there was some dirt. cleaned and reoiled, good as new!
also dont forget to teflon tape the top screw, its a source for boost leak
Old Nov 28, 2007 | 11:27 AM
saiyanzzrage's Avatar
bump
Old Nov 29, 2007 | 03:34 PM
(GSX95)'s Avatar
I'm running a Type S with one spring because i had compression surge, but thats on a DSM.
Old May 6, 2009 | 09:28 AM
mc14's Avatar
I have this valve and put it in straight car runs fine, no flutter
Old May 9, 2011 | 12:30 PM
4cdndctn's Avatar
Thread resurrection!
I've had this BOV for almost 2 years and I'm still trying to figure out how I want to adjust it. The one spring mod seems better for street driving and both springs seem to perform better on track although with both springs it seems prone to surge in certain part throttle scenarios.
I have tried the 1g, crushed 1g and both the dejon kit and the RS seems better for me. I may buy a new BOV just to try something different. I also wonder how much of a role my Buschur UICP plays in the behavior of the BOV? Hmmm
Old May 9, 2011 | 02:59 PM
dastallion951's Avatar
personally ive had my greddy rs mine is set at two-three threads from totally stiff...i can hear a small pshh even at 5 psi, but im tuned to run 26 psi peak, i think honestly in your driveability issues, a good tuner should be able to tune it out from stalling at idle....very seldomly do I get that issue.
05stikiller
Jan 30, 2009 11:04 AM
philamthebest
34
Jan 29, 2009 09:49 AM
Perfect Tool
Jun 12, 2007 08:27 AM
highvelocitykid
Sep 8, 2006 03:07 AM
supercharged
Jan 31, 2006 05:14 AM
