Cooling fan switch
Old May 4, 2006 | 04:28 AM
justchil's Avatar
and one more.... bump
Old Mar 28, 2008 | 05:59 AM
honki24's Avatar
Okay, back from the dead. I want to switch my AC fan on and off manually for the track. How can this be done without damaging the any relays or controllers?
Old Mar 28, 2008 | 08:08 AM
honki24's Avatar
lunchtime bump
Old Mar 31, 2008 | 10:26 AM
honki24's Avatar
Seriously... someone.
Old Mar 31, 2008 | 10:59 AM
lemmonhead's Avatar
you can put a relay 2pole double throw type to make a resistor to take the place of the fan, fan disconected by relay. does this make sense?
Old Apr 1, 2008 | 08:58 AM
honki24's Avatar
sorry man... unfortuantely it doesn't make a lot of sense. At a glance I see two plugs that go to the AC fan which wire on which harness would I tap? Where would I put a resistor? What size would I use? Would I be applying power or ground?
Old Apr 1, 2008 | 11:47 AM
lemmonhead's Avatar
here is how its connected.
normal position 1 is shorted to 3
2 is shorted to 4
after you trow the switch. 3 is shorted to 5
4 shorted to 6
all you have to do now is wire your power 12v source from 1 and 2 to power the fan.
do you understand now?
Old Apr 2, 2008 | 10:00 AM
honki24's Avatar
lol that pic was freaking awesome. Don't have time to really look into it at the moment, but I sure do appreciate all the effort, I'll get back at it asap.
Old Apr 2, 2008 | 11:13 AM
honki24's Avatar
Alright, after looking at it:
-I want to wire the AC fan, not the regular radiator fan.
-Do I merely tap the wires on the diagram or am I cutting them? I want the car to continue to have OE functionality for the AC fan.
-lol how will I know which wires those are in real life? I can read a wiring diagram... but I can't easily transfer that to the real thing in my mind. The wires that go into the AC fan can be seen through the front bumper on the left side (if you don't have a massive IC). It has 2 separate harnesses going to it... I wouldn't know which to work on. Any way you can work your MSPaint magic on a real picture of the wires on the AC fan? lol, I know, I suck... and I'm sorry.
Old Apr 2, 2008 | 11:29 AM
lemmonhead's Avatar
"Has anybody installed a switch to activate the radiator cooling fan"
this is what you said in your first post. i guess im lost on what the heck you wan tto do. if you want to wire in a AC fan, then just get a 12Vdc to 120VAC converter, and plut your fan to it. easy and you dont have to wire into any factory wires at all.
Old Apr 5, 2008 | 02:22 PM
honki24's Avatar
lol, I think we're miscommunicating. By AC fan I mean the auxillary cooling fan that is between the IC and the radiator. (It's a "pusher" fan)
-Also I'm not the OP so that wasn't my question, I'm concerned with the AC fan, not the normal fan. The AC fan will blow air over the turbo and pull it through the IC, so I think it would be more advantageous. Sorry to yank you all over the place man, but thank you for being willing enough to help. I just barely struggled by my EE classes for a reason.
Old Apr 23, 2008 | 12:26 PM
honki24's Avatar
Figured something out. Much easier this way, perhaps it can help others: https://www.evolutionm.net/forums/sh...44#post5579644
Old Apr 23, 2008 | 03:22 PM
Balrok's Avatar
Originally Posted by justchil
bump... anyone?
Now that I'm thinking about it.. would be cool to turn both fans on with a switch hmm...
+1
Old Apr 24, 2008 | 12:47 PM
honki24's Avatar
... did you just see my last post? That link will describe how to turn both fans on...
Alchem1st
Mar 15, 2022 08:47 AM
foxbear2277
Aug 16, 2012 05:09 PM
utggevox
Jun 10, 2012 04:30 PM
Thebigjoke1337
Aug 18, 2011 10:28 PM
98autogstspyder
45
May 16, 2009 12:23 AM
