any garrett t-67 owners???
Old Jul 11, 2005 | 10:04 PM
silverofs's Avatar
i know a few of you have the greddy t-67's but how many of you have a garrett t67?? what wheel combinations do you have??? t3? t4? just curious thanks
Old Jul 12, 2005 | 07:18 AM
David Buschur's Avatar
The Garrett T67 is HUGE, nothing like the small Greddy T67 kit. To give you an idea the T67 is what I had on my tube chassis car that ran 7.8 at 175 mph. This is a full T4 turbo.
David Buschur
www.buschurracing.com
Old Jul 12, 2005 | 08:31 AM
silverofs's Avatar
i know how big the t67 is i have the t3/t04s t350 .63a.r t67 i was just wondering if anyone is running this turbo or the t4 version like you said.....
Old Jul 12, 2005 | 02:58 PM
jid2's Avatar
I'm running 35 lbs out of mine and revving to 9K! It's Boss Just Joking Don't be a hater.
Everywhere Zach... Everywhere.
Old Aug 2, 2005 | 10:58 PM
slowTsi's Avatar
Holy mismatched compressor to turbine wheels....
Old Aug 3, 2005 | 10:58 AM
Geoff Raicer's Avatar
you're looking at the minor not the major dia. the major is very similar to a gt35R...
Old Aug 3, 2005 | 11:25 AM
mike 99gsx's Avatar
The T350 wheel is not small. Its actually a proven combination with the T67 compressor wheel back in the day before GT wheels were all the rage. The .63 exhaust A/R is probably a little too tight though.
Old Aug 3, 2005 | 09:36 PM
slowTsi's Avatar
I still think it is kind of small for this compressor, especially in a .63 T3. If I was going to try the .63 if would definately be with a p-tirm to help reduce the intake to exhaust pressure. On one of our motors you are looking at running 35psi+ to get the what you want from this compressor, in which case you need more turbine housing and wheel. I am sure the pressure ratio is strting to get ugle at higher pressures. That is all I meant.
Geoff- I just posed this question in the DSM part of your forums the other day if you want to take a look
Old Aug 3, 2005 | 10:05 PM
topnotchevo's Avatar
T-67 602awhp 541ft.lbs.@32psi on c16 with plenty left.NO LAG,feels like a big block
Old Aug 3, 2005 | 10:28 PM
slowTsi's Avatar
What are the specs on it (turbine housing and wheel)
thx
Old Sep 3, 2006 | 09:49 PM
tony gibson's Avatar
When does boost come on? I will be doing Sheare's BBT-67 kit soon on the stock bottmom end and am wondering how well the spool is....A little worse than a 35r I would guess?
Old Sep 3, 2006 | 11:24 PM
kjewer1's Avatar
I ran a Garrett T67 on the 2g. TO4S cover, O-trim in an .82 t3 housing. With a 2.3 I was getting 29 psi at something under 5k rpm. That was the highest boost I ran before I parted the car, but it moved 65 lbs/min at that boost level on the 2.3. With a 1.8 60 foot it was good for 11.3 at 126, but I lost the motor in 4th due to running a 255LP pump. Didn't realize it was out of steam until I looked at the logs later on. There was definitely a 10 second pass in this thing even at that boost level, with more boost it's a very good turbo. Nice step up from the 35R based turbos. It was too close to the end of the season so I bailed out on the setup, so I didn't get to try it at higher boost levels, which is still dissappointing even 2 years later.
Old Sep 3, 2006 | 11:31 PM
GTREVO's Avatar
Is this the non ball bearing version?
Old Sep 3, 2006 | 11:47 PM
kjewer1's Avatar
In my case, it was not.
Old Sep 4, 2006 | 12:07 AM
GTREVO's Avatar
Mind me asking who build this turbo for you? I have always been contemplating to purchase this but worried bout the lag it might have over the GT35R.
