power switch for alky kit
Old Jul 13, 2005 | 07:21 AM
Derek888's Avatar
Any of you installed a on off switch for alky injection? Would it be better if I hook it up to the red fuse wire?
Old Jul 13, 2005 | 07:56 AM
3deep's Avatar
What kit do you have.I run the smc and the red wire is what i used.I run a 25amp from radio shack in the pulldown coin tray.
Old Jul 13, 2005 | 08:13 AM
Derek888's Avatar
I also have the SMC kit. got any pics of the switch?
Old Jul 13, 2005 | 08:45 AM
3deep's Avatar
No pics,its just a standard toggle.I mounted my controller in the center console so i can monitor the spray lights.
Old Jul 13, 2005 | 08:53 AM
GOKOU's Avatar
Why not use the stock spray controller on the center console as the switch to SMC alky kit?? Is this even possible?
Old Jul 13, 2005 | 08:55 AM
gsujeff55's Avatar
how can you monitor it in the center console? you mean, the elbow rest console, right?
i mounted mine in the coin tray and can monitor all the lights pretty good while driving....might be moving it though, if i knew where you were talking about.
i would like a switch as well...although, id have to switch maps at the same time
Old Jul 13, 2005 | 12:59 PM
FlyNavy's Avatar
I'm tapping a red led to my A pillar for "low" and a green for "spray on". That way I can leave the coin tray closed and not have to look down for important lights when I'm on high boost. I also plan to run an On/Off switch to block/connect the fused red power wire, maybe with an led there too to light up when power is applied. Its like a $5 Radio Shack mission and very easy to rig...
I don't like the stock intercooler spray switch idea because it is momentary and you don't know what position its energizing. I like to see and feel the switch click on and off.
I'm thinking of totally geeking out and making the power switch also switch my EMS to a lower-boost map below the turn-on threshold of the alky to prevent going high with no alky and frying something. So the procedure would be: see the red led on the a pillar, flip the switch and effectivily turn off the alky and prevent boosting past the threshold of needing it. All with one idiot-proof switch.
I think this kind of forethought is vital if we're going to safely run these systems. The gains are awesome, but they come with (preventable) risk. I want an alky system failure to reduce my engine to a safe slow-turd status rather than pile of broken sh%t.
Old Jul 13, 2005 | 01:22 PM
gsujeff55's Avatar
wow, you should patent that and sell them. Id pay 20 bucks for it....
Old Jul 13, 2005 | 02:25 PM
EvoTech's Avatar
I pulled out the intercooler switch and put a marine grade rocker switch in it's place. It required a bit of triming to the bezel that held the switch, but when all was said and done, it looks like factory. I am very happy with it.
Old Jul 13, 2005 | 08:06 PM
Derek888's Avatar
doesnt the coin tray get in your way if its pulled down while driving? I might just mount the controller next to the coin tray and have a on off switch behind the panel...
Old Jul 17, 2005 | 05:29 PM
gsujeff55's Avatar
lets see pics and maybe a wiring explaination.
Old Jul 17, 2005 | 05:30 PM
gsujeff55's Avatar
yo, you have any pics of this setup?????
