View Poll Results: What downpipe bolts did you use?
I used the stock bolts with spring
58.06%
I used aftermarket metric bolts (no spring)
41.94%
Voters: 31. You may not vote on this poll
What bolts did you use on your downpipe?
Old Jul 13, 2005 | 08:52 AM
Jeff_Jeske's Avatar
Question What bolts did you use on your aftermarket downpipe?
AFTERMARKET DOWNPIPES ONLY
Just curious if more people discard the stock bolts with springs or if they reuse them.
Installing my DP tonight.
JJ
Old Jul 13, 2005 | 09:01 AM
en1gma19's Avatar
Stock for me, no problems.
Old Jul 13, 2005 | 09:03 AM
jerdeitzel's Avatar
Well it depends if the dp uses the stock donut! if i does i would use the stock bolts. if not use shorter ones with no springs
Old Jul 13, 2005 | 11:20 AM
krayzeviet's Avatar
i have a buschur and it doesn't use the stock donut.... it also came with it's own bolts and springs..... which is a must since i tried to reuse the old ones and they would just get in the way of the actual piping since it's bigger
Old Jul 13, 2005 | 11:22 AM
mooreboost's Avatar
Buschur bolts and lock washers.
Old Jul 13, 2005 | 11:23 AM
justchil's Avatar
ditto
Old Jul 13, 2005 | 11:28 AM
ddubb's Avatar
bolted on an espilir 3" DP with the stock bolts w/ springs
Old Jul 13, 2005 | 11:29 AM
SPIN2GST's Avatar
Buschur bolts and lock washers, worked fine for me.
Old Jul 13, 2005 | 11:30 AM
Tsurara's Avatar
I had to cut my bolts off (Thanks MA winters) so I used the ones WORKS gave me.
Old Jul 13, 2005 | 03:03 PM
Nemesis3's Avatar
bolt/washer
sup D (got my text)? yeah used the stock bolts for the Espelir DP...but gotta check it again thought, I think I may have to go with a shorter bolt or put a washer or two on the stock. Sounds I'm hearing, it's like a leak but I checked but no leak anywhere else.
Old Jul 13, 2005 | 03:29 PM
Quicksilver II's Avatar
Buschur downpipe, his bolts and washers.
Old Jul 13, 2005 | 03:36 PM
Zeus's Avatar
Megan downpipe with stainless steel bolts,lock washer, flat washer, anti-seize... the damn thing comes off all the time... good bolts!
I highly suggest getting your own for any downpipe that does not use the OE donut correctly.
Old Jul 13, 2005 | 03:41 PM
ddubb's Avatar
^^sup V, sorry off topic, didn't know you had an issue, let me know when you are planning on working on it. call me when you go to autobacs want to see how it is.
Thegame's Avatar
On my HKS dp I was instructed to re-use the stock spring bolts... The problem is that when they are loose, the dp leaks and when they are tightened the whole way down, the springs are fully compressed. I posted a thread about this and no one seemed to know anything.
Old Jul 13, 2005 | 04:57 PM
Thegame's Avatar
bump for some more responses
