Vid: Is this normal for a trans?
Old Jul 14, 2005 | 07:25 AM
evo 8 ya's Avatar
video here
The trans is from a 03 with 18k on it, that keeps throughing a PO300code. Could this be the noise that has been plaging our cars? This is the loudest one I've heard and it has the most play that I've see in a evo.
Old Jul 14, 2005 | 07:35 AM
sleet's Avatar
.mov blows
Old Jul 14, 2005 | 07:39 AM
DCSilvrEvo's Avatar
DAMN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Im about 2 get m tranny replaced. Ill see if mine does that. ummm thats the output to the transfer case right?
Old Jul 14, 2005 | 07:44 AM
evo 8 ya's Avatar
Originally Posted by sleet
.mov blows
It's pretty good for a digital camera
Old Jul 14, 2005 | 07:45 AM
evo 8 ya's Avatar
yes it's the output shaft for the t-case.
Old Jul 14, 2005 | 07:47 AM
GEARS's Avatar
That is the inner hollow shaft that drives the front differential. That shaft goes all the way through the center diff and is splined into a side gear. The reason it's loose is because: it's going into splined side gear. It's fine.
Jon@TRE
Old Jul 14, 2005 | 07:52 AM
evo 8 ya's Avatar
Jon@TRE
Cool thanks, but that's just alot of play. So what causes the "griding" noise that goes away when you push on the clutch. Something is causing this po300 code. I think it's the vibration from the trans that the knock sensor is picking up as "knock". The car does have a reflash.
Old Jul 14, 2005 | 09:50 AM
titaniumkingpin's Avatar
i too have a slight grinding noise that stops when the pedal is pushed in.
Old Jul 14, 2005 | 09:51 AM
and i also USED to throw the P0300 code. It magically stopped though. Nothing was changed. Weird
Old Jul 14, 2005 | 04:11 PM
GEARS's Avatar
I know that the transmission has been blamed for the pesky PO300 random miss-fire code and there are several people who told me that it doesn't happened after I've rebuilt their transmission. I guess I’m impressed with the sensitivity of the knock circuit to pick up gear-knock.
Jon@TRE
Dr-Gonzo
Mar 6, 2017 08:42 PM
Epyon
Jul 19, 2016 08:14 AM
My03evo
Apr 21, 2011 10:03 AM
4ringturncoat
16
Sep 3, 2007 03:25 PM
wannabeanevo
Jul 30, 2007 08:15 AM
