GT35r spoolup answers here
Old Nov 24, 2005 | 03:49 PM
  #211
sethrichmond's Avatar
just logged 3rd gear pull
buschur freakin everything in my car except the manifold set up that is all ronny shearer.
beautiful
buschur stroker too
started the pull at 2000rpm
91 octane pump gas at 4500 feet above sea level. (i heard they spool better at sea level)
18psi at 4500rpm
boost was set at waste gate pressure
Old Nov 24, 2005 | 07:31 PM
  #212
silverofs's Avatar
beautiful
buschur stroker too
18psi at 4500rpm
seth your turbo is the ball bearing gt-35r right?? not just the 61mm standard bearing?? that seems slower than i expected.. if your running it off the wastegate spring it spools slower, run it off your aem or mbc & it will spool faster.
Old Nov 24, 2005 | 07:48 PM
  #213
the manual boost controller is hooked up. it is just screwed all the way out so it effectively out of the loop.
are you saying that i should turn the boost up a hair so the the boost controller is regulating boost?
Old Nov 24, 2005 | 08:04 PM
  #214
silverofs's Avatar
it seems if you run with the boost control it will have faster spool up because it controls the wastegate better. with the wastegate working the boost control it slowly opens so it slows the spool up process.
Old Nov 25, 2005 | 08:27 AM
  #215
i have to have you show me next time you see me.
oh, i am running the 6 speed mr tranny. my third gear is a lot lower than the 5 speed. it would spool slower.
Old Nov 26, 2005 | 08:39 AM
  #216
rACerS's Avatar
Isnt power output more important than boost? Id like to see a stock turbo vs gt35r in a roll on in the same gear. And see when the 35r starts to pull on the stocker.
Old Nov 26, 2005 | 08:40 AM
  #217
rACerS's Avatar
Originally Posted by fre
I run 11.50 with a 35R stock block and stock ecu. Hrmmmm no stock turbos doing that with the stock ecu I could be wrong though? Prove it to me Lag really isn't that bad as long as you are a competent driver and don't shift like a monkey (i.e. shifting from 2nd to 5th).
it has been done
Old Nov 26, 2005 | 09:17 AM
  #218
TrinaBabe's Avatar
The stock motor part does not help or hinder running anything powerwise... most people build motors to handle the power, not make more. The 'stock' ECU thing is kinda becoming a joke.... what exactly does stock mean? You have bigger injectors, the 'stock' ECU will not handle those. You are using an AFC to lean it out, therefore, it is not stock anymore. Its the same with reflashed cars... its not a stock ECU anymore, it is a stock ECU that has been modified. I guess my car I could say has the stock ECU... my car still uses the stock ECU.. I just modify the timing and fuel tables alot.
Old Oct 1, 2006 | 07:49 PM
  #219
AlwaysinBoost's Avatar
I'll add my spool up data to this old azz thread now that I have the 35r installed. I'm running a standard RNR 8gauge manifold with the WG re-routed back into the DP. Currently boost is set at only 18psi because I'm still tuning but I can feel a pretty big rush from about 4k up. I can't wait till I get it tuned to 24psi.
Incase thats too hard to read :
RPM - boost
3120 - 1.7
3540 - 3.46
4010 - 6.29
4560 - 10.84
5070 - 14.33
5520 - 16.67
6010 - 17.60
6530 - 17.66
I started the pull @ 2500RPM. Even though the MBC is set to 18psi it doesn't reach that in 2nd gear I'm guessing because there isn't enough load on the engine.
I'm really suprised how fast the spoolup is, I was expecting much much worse. There is a huge difference between 10psi on a 16g and 10psi on a 35r, I can't wait until I get up to 24psi.
According to some quick calcs with the 1000cc injectors I'm using I should be about to push around 26psi safely on pump gas alone...
Old Oct 1, 2006 | 08:08 PM
  #220
Smogrunner's Avatar
Give us a third or a fourth gear pull and log when you hit 20psi. Mmkay.?
I'm really glad you resurrected this thread, it was one of my favorites.
Old Oct 1, 2006 | 08:32 PM
  #221
THe reason I posted a 2nd gear log is because thats what the majority of logs in this post are from.
I'll be back out tomorrow doing more tuning so 3rd & 4th shouldn't be an issue, hopefully 20psi wont be either.
Old Oct 2, 2006 | 12:09 PM
  #222
Guerillah's Avatar
I'll have some data in a couple of weeks hopefully.
Old Oct 2, 2006 | 06:57 PM
  #223
Did more tuning tonight as promissed. I'm taking it real slow so I'm only up to 19ish psi but its getting there. I still can't believe how little lag there is.
I did 2nd, 3rd, & 4th gear logs. All on the same level stretch of road. I think the car is spooling pretty quick compared to other logs posted in this thread.
2nd gear below:
3rd gear below:
4th gear below:
comments...
Old Oct 3, 2006 | 10:29 AM
  #224
all the 35r evo's out there and nobody has anything to add???
Old Oct 3, 2006 | 04:57 PM
  #225
fre's Avatar
fre
Pretty much how my log looks. I don't know how people get full boost in 3rd by 4k.
