EVO 6 TME Vs 10.5 Hotside???
Old Jul 21, 2005 | 07:25 AM
bdking57's Avatar
spool is slower with the the hostside.. but lower ic pipe and other mods can decerease spool time.. TME turbo is still a much better mod then the 10.5 hotside if you can get it for a good price. The hotside is essential just giving you what ever 2005 evo has, which is better but nothing out of the ordinary.
Old Jul 21, 2005 | 09:39 AM
EvilBlueEvo8's Avatar
thanks bdking57
Old Jul 21, 2005 | 09:43 AM
marksae's Avatar
After I installed my 10.5 hotside, turbo lag was definitely more noticeable. However, WORKS updated the boost map on my P2 flash and that helped spoolup significantly. Now, the extra lag induced by the 10.5 hotside is barely noticeable.
I kept my stock exh man and o2 housing. I did port-match all the components. The porting I did was very minor. I don't think it made much difference.
Old Jul 21, 2005 | 10:01 AM
NapervilleEVO's Avatar
can't you get the titanium wheel sperate with a hotside? will an safcII be sufficient enough to tune for a TME 6.5?
Old Jul 21, 2005 | 10:31 AM
titaniumkingpin's Avatar
stupid question but.......
does this mean that the 05' with the 10.5 spool later than the 9.8 03-04 evos? im talking about stock to stock.
Old Jul 21, 2005 | 10:56 AM
marksae's Avatar
Yes. But the 05s also have an improved wastegate design, so this may offset the lag a little bit.
Old Jul 21, 2005 | 11:03 AM
gnulooks's Avatar
I've driven Evos with both the TME and hotside. The only real difference is that the TME spools about 200 RPM sooner than just throwing on the hotside. My hotside would hit full boost by 3200 RPM and the TME at about 3000 RPM.
Also, for some reason the TME seems to make a little more power on a fully moded Evo. Your probably looking at 15 to 20 more HP. However, the midrange power on both turbos is really strong and almost identical...
Old Jul 21, 2005 | 11:04 AM
MYFIRSTEVO's Avatar
Ive been running with the TME and I have no regrets at all. Noticable advantage is on the spool up. I've ran it with another EVO with exact mods... only difference is that I have the TME and he doesn't... I left him about 1-1 1/2 cars behind on 4th gear.
We both agreed that the TME spools 1k advance/faster than the stock turbo through redline. So by the time I shift... the other car still has 1k more rpm before he hits redline. (Mods: cams, tbe, injectors, safc, pump..stage 1+)
Just from my past experiences.
Old Jul 21, 2005 | 11:18 AM
great reviews, thanks guys.
Old Jul 21, 2005 | 11:21 AM
marksae's Avatar
How much difference did you notice on the transient boost response between the two?
Old Jul 21, 2005 | 01:20 PM
gnulooks's Avatar
Both turbos hold an equal amount of boost, whether on 91 octane or 100. I believe the only real difference is that the lighter titanium center section allows the TME to work a little more effieciently to produce early spool up and more power.
Old Jul 21, 2005 | 02:06 PM
bdking57's Avatar
is the response between gears that most intrested me in the tme.. there are alot more parts then just the wheel.. its more like the shaft also and other little goodies. Its more cost effective to just buy a new one rather then trying to build one. They are going used for as little as 800
Old Jul 21, 2005 | 02:17 PM
gnulooks's Avatar
To tell you the truth, I did not notice any response difference between gears or after shifting. Both cars felt strong and the TME car had a few more supporting mods, which helped out with making more power.
Unless you really go out and drive two Evos like I did then you are speculating on a lot of things. Both setups are good with the only major difference being earlier boost and a some more power from the TME. I did not see the need to spend the extra 800 dollars for the TME turbo. I figured I would save my money and buy my aftermarket AMS 3071 kit, which equalls big power...
Old Jul 21, 2005 | 07:49 PM
thanks guys. this is the info i was trying to search for but couldn't find.
Old Jul 21, 2005 | 09:47 PM
Soon 2 B EVIL's Avatar
yeha i might just do the 10.5hotside till the new year before upgrading to somethign else bigger.
