Evolution Drivetrain for Dummies
Old May 29, 2010, 08:27 PM
  #76
Johnnyangel16's Avatar
Thanks! I've had it apart once already, this would have made it a lot easier to figure out the first go around..
Old Jun 4, 2010, 12:17 AM
  #77
ElectrIX Blue's Avatar
thanks!!!!!!this post really help me alot
Old Jun 8, 2010, 01:13 AM
  #78
DownunderSiR's Avatar
Great work, very helpful.
Old Aug 16, 2010, 04:52 PM
  #79
groundlogic21's Avatar
Awesome! Lots of useful info
Old Sep 14, 2010, 11:11 PM
  #80
Dann's Avatar
Good read I saved this for future reference!
Old Jul 21, 2015, 03:17 PM
  #81
Zanew's Avatar
Drivetrain diagram.
Hello,
The very first post on this thread by SuperHatch back in 2005 contained a really good PDF of the Gearbox and Transfer box from what is I believe an EVO1,2 or 3. (see attachment)
10 years is a long time so I don't know if SuperHatch is still a memeber but I'm sure some of you guys can put me right.
Sadly I am not an Evo owner but I am hoping to use the running gear from one to build a hillclimb car. Don't worry I won't be cannibalising a decent car, only a scrappy!
I have exchanged a couple of emails with a guy in Australia who has use EVO running gear in a mid engine, 4wheel drive configuration. In the standard car the engine overhangs at the front so if you shift it all back to mid engine then as you can see from the diagram the driveshafts (now driving rear wheels)are now behind the engine so great weight distribution but oh dear the central output shaft is pointing the wrong direction.
My aussie acquaintance tells me he has modified the casing and output shaft to make it point forwards but he hasn't given me too much info so this is why I'm tapping up you guys.
There is really just a couple of things I would like to check:
1. I want to make sure I'm looking at the right thing. Is the diagram of an EVO 1,2,or 3 as this is the model range he tells me he has modified. He describes it as "the right angled shaft" type transfer box.
2. The diagram shows the box in plan view. I can see where the bell housing would join on to the gearbox. For the central output shaft to point the other direction it would have to pass below the engine. Ignoring all the complexities of actually engineering this, does the transfer box sit low enough to do this in the first place?
3. Does it sound as hard to you as it does to me!! The australian guy, Glen (he has a name) says he did it all in his home garage.
Any guidance appreciated.
Cheers.
File Type: pdf
Old Jul 22, 2015, 12:57 AM
  #82
Yogi_B's Avatar
That diagram is for an evo7-9, as the transfer case has the ACD stuff shown.
Old Jul 22, 2015, 09:43 AM
  #83
barneyb's Avatar
Anyone know what the tiny hole sealed with an o-ring between the transfer and transmission is for?
Steve?
Nov 5, 2015 03:23 PM
Steve?
Oct 29, 2015 07:39 PM
steve0677
Aug 24, 2015 11:58 AM
Big Steve
Jul 30, 2015 03:22 PM
steve0677
Jul 9, 2015 05:39 PM
Quick Reply: Evolution Drivetrain for Dummies
