putting a perrin crank pulley hurt my motor??
Old Aug 7, 2005 | 08:13 PM
trinydex's Avatar
Originally Posted by Joe's_EVO8
There are many more defective MBC's out there rather than pullies. I will not reject this "twang" you are talking about. Although these "high hp" engines are built to higher tolerances than a stock engine therefore attributing a pulley by itself to crank or bearing failure is foolish. It would be like saying my lighter flywheel caused failure. A pulley does not cause failure. A stock motor is built looser. A pulley is not going to cause failure and I have not yet seen one 4Gxx owner complain or prove that a pulley caused failure.
What I will say though is there are many ways to get power, this is just one of them and all of them take chances.
i do admit that the crankshafts will be way beefy... but higher hp means higher impulse twang. i mean every piston cycle gives you a a wobbling crank shaft... it can only do that so many times. and there will be times when the rpms are in that sweet spot when you get high amplitude twanging. nothing at al like a flywheel... cuz a flywheel is balanced and doesn't contribute or rather take away any damping.
i mean it's totally up to the person. i personally think that pulleys are great... i would want one made with a damper tho. cuz the kinda gain you can get across the board is really not able to be found anywehre else (assuming you're fully tuned out in all other aspects).
i think it's a sad byproduct of lazy profit seekers that's produced the kind of stuff we have on the market today. it don't take anything to machine a uniform density piece of aluminum.... and that's as far as their research and quality control goes. that's it... find a nice uniform piece of al and then machine it to exact tolerances. that's crap... it's not that hard to copy even a RUBBER damper... why not just DO it and have something that is oem caliber? total laziness.
Old Aug 7, 2005 | 08:34 PM
timzcat's Avatar
I agree it would be nice if some of the domestic parts companies would step up and make some good dampers like those available for american cars.
Old Aug 8, 2005 | 07:16 AM
Ludikraut's Avatar
^ +1
l8r)
the_cosworth
Lancer Engine Tech
56
Aug 9, 2007 09:16 PM
_EVOlved_
151
Nov 26, 2006 06:04 PM
iufan4lifeul
Nov 9, 2006 05:42 AM
CarPhoto.net
11
Mar 10, 2005 07:38 PM
tx evo
34
Nov 26, 2003 12:58 PM
