boost guage needle vibrates bad
Old Jul 24, 2005 | 07:38 PM
Derek888's Avatar
After my cams were put in I notice my boost guage needle is vibrating pretty bad during idle. It works fine and all but the way it bounces and doesnt keep still is bugging me when idling. Do you think it might have to do with the boost line, its not secured down just kinda hanging in the engine compartment which may also be vibrating as well.
Old Jul 24, 2005 | 08:06 PM
marksae's Avatar
What boost gauge are you using? I have the greddy gauge and my needle vibrated a lot before I put the restrictor in the line. That helped smooth things out.
Old Jul 24, 2005 | 08:13 PM
Widebandphillip's Avatar
You're fine.
Old Jul 24, 2005 | 09:46 PM
Derek888's Avatar
Originally Posted by Widebandphillip
You're fine.
are you saying this is normal?  BTW I have the Defi boost guage
Old Jul 24, 2005 | 09:48 PM
mike1023's Avatar
hey my **** does the same thing i have a stock car. but my does it when i build boost. or ac on and at idel it move a bit. but i almost think its a leck from the boost gauge to it. or maybe even somewere else. but also happens most when hot out. so there for somthing with the hose going to it. so next time it happens in hot i will pull over but a zip tie on the hose where the t connecter is and see if stops the problem.
Old Jul 25, 2005 | 10:28 AM
Fenris Ulf's Avatar
Boost should 'vibrate' at idle since the twin scroll turbine housing accentuates the pulse hits to the blades.
4b11slayer
Sep 30, 2016 07:26 AM
2StepsAhead
35
Feb 10, 2015 03:27 PM
RoryMarckese
Feb 7, 2012 05:54 AM
SIC SIK SIX
Jun 21, 2005 10:10 AM
psionic98
Oct 10, 2003 12:01 PM
