My evo is boostin early with Hallman manual boost controller
Old Jul 26, 2005 | 08:05 PM
03silverevo8's Avatar
Unhappy My evo is boostin early with Hallman manual boost controller
I just recently installed my Hallman manual boost controller and I'm currently running 20 lbs, my boost usually kicks in about 3,200 or 3,500 Rpm some where around there and now my boost kicks in at 2,900 or 3,000 Rpm, I'm wondering if there is something wrong with my car like a boost leak or something? Can someone let me know something? My mods are 3" Helix downpipe, 3" megan racing hi flow cat, 3" megan racing full exhaust, Aem short ram intake, Hks Bov.
Dee
Old Jul 26, 2005 | 08:10 PM
Evo_Tuner's Avatar
A boost controller helps bring boost on earlier by manipulating the vacuum to the wastegate. It's better!
Old Jul 26, 2005 | 08:11 PM
Spec'd's Avatar
First of all. With the modifications in your signature,
is a/f tuned properly.
Also, you might want to double check your MBC installation and hook-up.
There is lots of information on this forum and other Evo forums about
MBC's.
Old Jul 26, 2005 | 08:13 PM
when i drive, i barely press the gas and it hits boost quick feels like an automatic sometimes but when i push it my car pulls hard it jumps from 3,000 to 5,000 fast
Old Jul 26, 2005 | 08:25 PM
blueo4's Avatar
why 2 different thrs?????????
J Dog's Avatar
Ummm...how's that a bad thing?
well yall can make fun of me its not gonna hurt my feelings this is my first time having a boost controller on my car i just wanted to know if i did anything wrong and all you can do is laugh at me
Old Jul 26, 2005 | 08:27 PM
i just wanted to see which thread that people write me the most
Old Jul 26, 2005 | 08:29 PM
this is how i installed it
Old Jul 26, 2005 | 08:30 PM
KillaSweep's Avatar
decreasing turbo lag = good.
Old Jul 26, 2005 | 08:31 PM
Spec'd's Avatar
How does your car pull after 5000 rpms ?
Old Jul 26, 2005 | 08:33 PM
MYEVO8U's Avatar
such hatred these days.... Damn you don't have to bash the poor guy... This is probably the first turbo car he has owned much less with a boost controller.
Ok let me try to explain this to you... Your car was boosting pretty good Stock.. You add the exhaust and intake= loose a couple psi, but yopu don't notice it from the power adition. Now with the MBC you have added the boost the car wants. And also with a boost controller the Boost will come on much quicker and last longer..... Spooling to full boost at higher RPM's is called turbo lag= not good for power. the sooner to full boost the better.
Have fun.... its a good thing.
Old Jul 26, 2005 | 08:34 PM
it pulls pretty hard and the boost stays at 20 lbs not like before. I just wish it doesnt boost when im driving normal
Old Jul 26, 2005 | 08:38 PM
thanks for being nice to me, i just hate it when people get on to me like that, and this is my first turbo car that ive owned. if someone wrote on here like i did i would have tried to help him out not be a jackass about it.
Old Jul 26, 2005 | 08:45 PM
donutmonkey's Avatar
Man - the guy asked an honest question.
An MBC works by creating a leak in between the boost signal and the wastegate actuator. It tricks the actuator into thinking the car is not making boost, by bleeding off the boost signal.
The reason the car is making boost earlier is because by installing the MBC, you have tricked it into thinking it's not making boost. The wastegate stays closed longer becuase the actuator doesn't see the signal. It's being bled off by the MBC.
Be careful! Make sure you're not running lean. You could melt pistons in a hurry. If you don't have an A/F gauge installed do so.
