best intake for your money!!!
Old Jul 30, 2005 | 02:06 PM
  #46
donmeca2020's Avatar
thats exactly why im somewhat confused, on what to buy. i've heard alota good things with aftermarket filter and pipe intake systems, i mean i wish some people could show like dyno numbers, because im interested in both the HKS racing suction or possibly just the apexi filter, but i would like to know what its really worth buying one of these ?
Old Jul 30, 2005 | 02:55 PM
  #47
Precision Dyno's Avatar
Originally Posted by shiv@vishnu
Your hot air induction system is only 20 degrees warmer than a fully sealed, cold air ducted airbox? Don't you think that is a bit optimistic when underhood temps can easily approach 200 degrees (or more when the radiator fans kick on)? I've measured turbo inlet temps of over 200 degrees on cars with aftermarket intakes.
Yes, intercooler does remove 80-90% of the heat generated through compression. But post IC temps will always be colder if turbo inlet temps are colder. And when there is no measureable vacuum in the turbo inlet tube, I think its safe to say that there is no power to be gained through "opening it up." So what you have in the end is a hotter intake charge, with a MAF that doesn't read airflow as well as it should and no measurable reduction in intake restriction.
With bigger turbos that move a lot more air, inlet restrictions may come into play. But with stock turbos that can only flow so much air, talking oneself into upgrading the intake is like trying to fix a problem that isn't there.
Just my 2c,
shiv
EVO 9's in japan often see huge differences in part throttle preboost A/F ratios when they change the intakes to an aftermarket unit.
The new ECU program has a lean spool map that will actually be detramental to the engine when this happens. The A/F target from mitsu is about 13.5:1. When the aftermarket intake is installed they are almost stoich.
Many blown manifolds are the result.
Whenever you increase the pressure differential you will see an increase or decrease in induction volume. Depending of course on the size of the inlet and the pathway.
So no offense but I don't agree with your post
I also don't understand the comment about the MAF having difficulty reading airflow. Could you please explain...
Old Jul 30, 2005 | 03:13 PM
  #48
ray3328's Avatar
Stock.
Old Jul 30, 2005 | 03:30 PM
  #49
Spec'd's Avatar
That sounded very intelligent. But are you saying that an aftermarket unit
is good or bad ?
Old Jul 30, 2005 | 03:31 PM
  #50
is good or bad ?
VERY GOOD so long as the A/F is right.
But Shiv is right that a cooler charge would be ideal.
They are correcting this in Japan before the EVO hits the shores here.
Old Aug 8, 2005 | 05:15 PM
  #51
hueman's Avatar
so even if you leave the airguide that connects to the stock airbox on with an hks intake, it will still suffer from 200 degree heat at speed?
Old Aug 8, 2005 | 05:16 PM
  #52
kmcconn9's Avatar
probably the injen, (for the money) because you get the uip, and intake together..
jmcmill3
Jul 14, 2012 08:52 AM
lookitznite
34
Apr 3, 2012 06:14 AM
gaulrich2003
28
Jan 8, 2006 05:50 PM
bobaab
93
Mar 30, 2005 12:45 AM
herbal77
Oct 23, 2004 09:13 AM
