Fuse keeps blowing can't figure out why?!?
Old Jul 30, 2005 | 05:43 PM
shiftdsm E's Avatar
Unhappy Fuse keeps blowing can't figure out why?!?
Hey guys, help please!!! In the fuse box under the hood, there are 2 fuses for the parking lights (right side and left side), and the one for the right side of my car keeps blowing out no matter how much amperage the fuse can handle. Its supposed to be a 7.5 but i found a 10 amp in there. I'm the second owner of the car and I think the guy who owned it before tapped the new guages he added into that fuse which is why it was a 10 amp, but why would it suddenly keep blowing it out? Also the dash panel lights aren't working so i guess its on the same fuse... any idea on how to fix this cuz i really dont feel like getting pulled over for my lights being out.
Old Jul 30, 2005 | 06:21 PM
badhabit90's Avatar
Cool
disconnect the gauge lights and replace the fuse to start. if your lights are now illuminated, then you have your problem solved. you will need to find another spot to connect the gauges to for them to illuminate. sounds like he may have connected them at the rheostat(the dash light rotory thingy to make them brighter or dimmer). =-) if the lights still blow the fuse then, you my friend, have an electrical short somewheres.....good luck
Old Jul 30, 2005 | 06:57 PM
shiftdsm E's Avatar
Thanks, Ill try it to figure it out tomorrow. I'm hoping that this isnt a short in the electrical system somewhere hard to find.
Old Jul 30, 2005 | 08:31 PM
sayanara's Avatar
You probably have open wire touching something and grounding, check the connections to the gauges and make sure you don't have any loose ends. Make sure your using the right fuse also. I had the same problem, it unded up being a wire which had touched a metal bracket.
Old Jul 31, 2005 | 08:55 AM
shiftdsm E's Avatar
After working on this problem some more I just realized how strange this electrical system really is, can anyone explain why the brake light, parking light, reverse light and dash panel lights be all on the same fuse...? The only thing that works on the right side of the car is the HID/Highbeam/Fog and the blinker...
Old Jul 31, 2005 | 09:43 AM
shiftdsm E's Avatar
Finally figured it out, stupid wiring harness for my cd player had an illumination wire partially exposed...
Old Jul 31, 2005 | 09:47 AM
Evoisdream's Avatar
lol this exact thing hapend to me! exactly i went through 7 fuses before figureing it out and the electrical is really weird like 1 fuse controlls interior lights back left tailight and a few little things..... how weird ahahah im glad u got it fixed
evoisdream
Old Aug 4, 2005 | 11:29 PM
badhabit90's Avatar
Cool
yup, that little wire will do it. good job there shifty!!!! way to trouble shoot...never would have thought of that unless i was there looking at an aftermarket radio.
AlexC330NY
Lancer Troubleshooting
Mar 29, 2016 08:36 AM
wmcorcor
Jun 3, 2009 09:58 AM
Spooky_Neo
Jun 24, 2008 02:04 PM
PG888
13
Oct 7, 2004 11:16 AM
nebolic
Dec 23, 2003 08:42 PM
