Whine when engaging 1st gear?
Old Aug 7, 2005 | 09:29 AM
93esp's Avatar
Question Whine when engaging 1st gear?
At the Oscoda ProSolo a couple months ago I noticed a whining in 1st gear under decel after a couple full throttle launches. A few passes later I broke a rear axle, hub, and suspension upright. Anyway I finally got the car together and the whining is still present.
Here are the symptoms: loud whining when engaging 1st gear with clutch disengaged and the car stationary. The same whining is present while decelerating in 1st. No whining under acceleration in any gear.
Thoughts?
Thanks,
Eric
Old Aug 7, 2005 | 09:39 AM
Rez90's Avatar
it sounds like either you TC or tranny.....possibly a syncro...i would take it to someone who really knows EVO driveline's
Old Aug 7, 2005 | 10:01 AM
93esp's Avatar
Normally I would suspect internal transmission parts with a whining sound. However, it whines loud with first gear engaged, the clutch disengaged, and the car stationary.... under this condition there are no parts moving inside the transmisison or transfer case....
Old Aug 7, 2005 | 10:02 AM
Rez90's Avatar
what kind of clutch
Old Aug 7, 2005 | 11:05 AM
93esp's Avatar
Exedy triple plate
Old Aug 7, 2005 | 11:18 AM
Rez90's Avatar
it might be the clutch...i have heard clutches wine a lot when being engaged/disengaged
Old Aug 7, 2005 | 11:40 AM
Rez90's Avatar
and full throttle launches cannot help any situation.
Old Aug 7, 2005 | 06:33 PM
GEARS's Avatar
You cracked the teeth on 1st gear.
Jon@TRE
http://www.teamrip.com/Evolution.html
Old Aug 7, 2005 | 07:07 PM
timzcat's Avatar
Yeah and if you are going to keep racing it you might as well click the link.
Old Aug 7, 2005 | 07:31 PM
elhalisf's Avatar
my brother chipped a tooth of his second gear in the wrx. sounds like the same thing. sorry to bring you the bad news
Old Aug 8, 2005 | 04:33 AM
93esp's Avatar
Thanks for the responses guys.... I'll pull the transmission tonight to check it out. Looks like I'll be getting a dogbox sooner than expected....
Eric
Old Aug 10, 2005 | 09:01 AM
93esp's Avatar
Well I have the transmisison apart... no broken gear teeth and nothing obviously broken. Any more ideas?
Eric
Old Aug 10, 2005 | 12:22 PM
metaphysical's Avatar
Registered User
Call TeamRIP or Shep racing and start asking questions
Old Aug 10, 2005 | 12:32 PM
GEARS's Avatar
Eric
Have the gears been wet-Magnafluxed or just inspected with the eye?
Have the gear wear patterns been inspected properly?
Jon@TRE
