White Rabbit Deals Another 400 Whp Dyno
Old Aug 9, 2005 | 09:31 AM
  #31
Ivan_C's Avatar
Originally Posted by sccavee
Does anyone have any track times on these?
Yeah, I've got track times, though the car goes faster everytime I take it out. I went from pulling consistent 12.2 - 12.3's @ 110 - 113 (on the stock turbo) to 11.8 - 11.9's @ high 116mph(WR). This is on full weight 3400-3500lbs w driver in 90+ degree heat and mid - high humidity. I can go faster but I'm out of 4th gear, I need a flash to bump the rev limit up. I'm confident the car will do 11.7's in 90 degree heat at 117-118+. This is with a very rough tune on the ECU+. Boost is 23->18 in 3rd and 24->20 in 4th. Then again I'm a better then average driver, pretty consistent 1.61 60' and one 1.57 to my credit.
Ivan
Congrats on the 400 pull.
Old Aug 9, 2005 | 10:08 AM
  #32
TalonRcR's Avatar
Originally Posted by NOLIMITMOTORS
Did you read what I wrote??? He made almost 400 whp on 24 psi. No one is doing that on the stock turbo. The WR i'm sure can do 28-30 psi and hold it better then stock and his car will probably make 420-430 whp at those boost levels. No one with Utec and stock longblock with just 272's is making 420+whp with UTEC
I have customers that make over 400whp on stock turbo.
Chris
Old Aug 9, 2005 | 10:29 AM
  #33
MM Racing's Avatar
Pump gas is for people who pump ***. You want to go fast and make good numbers you run race gas. Period. Last time I checked Top Fuelers and Pro Mod cars dont run waterinjectiona and 93 octane to make their big numbers.
Old Aug 9, 2005 | 10:31 AM
  #34
mike 99gsx's Avatar
YES!!!
Old Aug 9, 2005 | 11:02 AM
  #35
Ludikraut's Avatar
<shrug> ...nothing wrong with a good DP ... </shrug>
l8r)
Old Aug 9, 2005 | 11:11 AM
  #36
Chris@nolimitmotors's Avatar
Chris
on 24 psi???? PLease show me these guys. And I'm not talking about 30 psi tapering off to the 24 psi, i'm talking about no more then 24 psi. Thats what I posted.
Old Aug 9, 2005 | 11:12 AM
  #37
MalibuJack's Avatar
LOL Holy cow thats funny..
Actually pump/Alky should make similar numbers anyway.. But not sure about *****-out numbers.. But alky also has a cooling affect on the intake charge which helps things too.
Old Aug 9, 2005 | 11:15 AM
  #38
MalibuJack's Avatar
Yah this turbo produced a pretty stable 26psi, dropping to 24psi because the wastegate actuator was opening.. At least thats what I thought I recalled seeing.. What that means is the peak numbers would likely have gone higher if the wastegate stayed closed.
Old Aug 9, 2005 | 01:43 PM
  #39
AustinEVO's Avatar
What an azz............ Period. Last time I checked no one on here is a "Top Fueler or Pro Mod".
Old Aug 9, 2005 | 05:40 PM
  #40
mike1023's Avatar
wait ok i know runing a utec in there how much can a utec turn then a aem like can you or do you think you can get more power out of what you have with a aem
