How much power to expect from IC?
Old Aug 10, 2005 | 06:21 PM
4TUN8's Avatar
Kind of curious, how much power I could get out of my current set up by getting a bigger front mount and some IC pipes.
Current mods
3" TBE
Intake
Cams
MBC
320hp/330tq
Stock intercooler and piping at this time.
Old Aug 10, 2005 | 06:23 PM
hueman's Avatar
from what i've read, very minimal gains if any.
Old Aug 10, 2005 | 07:01 PM
mump's Avatar
little to none. piping will spool you up quicker though.
Old Aug 10, 2005 | 07:22 PM
Iceman2011's Avatar
^weird. more flow more power. its abt 20hp at the crank and the lower IC is abt 7 hp.
AMS is one of the best out there.
http://www.automotosports.com/evo_intercooler.asp
Old Aug 10, 2005 | 07:46 PM
whiteevo311's Avatar
there are two guys here locally that both got the buschar delux fmic and both picked up roughly 1-2mph in the quarter mile and 2 tenths with no other changes. Also seems that both cars were a little more consistant. Not to mention the bling bling factor!!! Id do it if i had 1000 lying around.
Old Aug 10, 2005 | 10:44 PM
hueman's Avatar
i wonder if it may be more difficult to pinpoint actual whp gains since there'd be substantial more airflow at speed than on a dyno.
Old Aug 10, 2005 | 11:53 PM
jxn evo 8's Avatar
there are other mods that you coulld do that would cost less and give you much more HP gains
Old Aug 10, 2005 | 11:55 PM
sylvester31's Avatar
from my own experience, very minimal gains.
Old Aug 11, 2005 | 01:55 AM
Str8Ryda's Avatar
Current mods
3" TBE
Intake
Cams
MBC
320hp/330tq
I think this may help your question about the FMIC.
http://www.socalevo.net/forums/viewt...ighlight=nisei
About the pipe kit I'm not sure, but rumor has it that Nisei will be doing some tests though.
Good Luck!
Old Aug 11, 2005 | 03:28 AM
4TUN8's Avatar
That much money for 13hp hardly seems worth it. I'm thinking alky injection maybe the route to go for cooling
Old Aug 11, 2005 | 03:29 AM
4TUN8's Avatar
What mods were you thinking of?
Old Aug 11, 2005 | 05:51 AM
Jasil's Avatar
You don't need to touch that IC until you upgrade the turbo and plan on pushing more than 425awhp.
Old Aug 11, 2005 | 06:49 AM
Warrtalon's Avatar
Alky and LICP would be the way to go here...
Old Aug 11, 2005 | 07:40 AM
4TUN8's Avatar
You've been pretty spot on so far. I think alky and LICP wouldn't even amount to the cost of a good FMIC and I'll probably get TONS more performance.
Old Aug 11, 2005 | 07:45 AM
Noize's Avatar
EvoM Administrator
Spool will be a little slower, because the bigger core will take longer to fill. I gained nothing with my AMS IC on the dyno, and lost about 200rpm of spool. Its good groundwork for a big turbo, but a waste on a 16G, Tommi Makinen, or white rabbit IMO.
