relocating bov with i/c pipe
Old Aug 14, 2005 | 11:04 AM
race17k's Avatar
i have a question i have a buschur intake but when i buy the upper i/c pipe kit i move the bov up their! so wat do i do with the flange where the bov used to be on the intake just plug it? this would def. look like crap! is their anyway around that?
Old Aug 14, 2005 | 11:18 AM
juyanith's Avatar
Are you asking if the bov should be routed back into the intake? Yes, unless you want the car to have stalling problems at idle. I've linked a picture from buschur's site that shows the upper ic pipe, bov and intake pipe that may help.
ct9a gsr's Avatar
There is no flange on the intake for a BOV to be mounted. There is an inlet made for a recirculation hose to be routed from a BOV to the intake. If you plan on using the stock MAF, plan on still using that recirc inlet and recirc hose with your BOV and new upper i/c piping.
Old Aug 14, 2005 | 11:21 AM
ries's Avatar
if you run the bov recirculated the outlet/discharge hose should run to the intake, you might have to buy a new hose to do this.
If the bov is run vta then you have to plug the intake up
Chris
Old Aug 14, 2005 | 04:21 PM
race17k's Avatar
right if i vta then their is no other way to get rid of that hole other than plug it?
Old Aug 14, 2005 | 08:31 PM
race17k's Avatar
anyone????
Old Aug 14, 2005 | 11:41 PM
ct9a gsr's Avatar
That is correct, you can just plug it. The easiest way to get around that recirc hole is to buy an intake without one.
bboy_RES
28
Aug 12, 2007 11:23 AM
jeff45
Sep 26, 2006 11:28 PM
jesterEVO
48
Dec 15, 2005 05:37 PM
Atlas
Dec 5, 2005 08:05 AM
tke_413
14
Nov 13, 2004 02:53 PM
