Boost ?
Old Aug 20, 2005 | 06:20 PM
PapitoEVO8's Avatar
Boost ?
Might be a dumb question. I just started noticing that when I cut the evo on the boost gauge stays at 0 psi for a little while (at least for a minute or more) then goes down. Everything seems OK. No CEL. Its that normal? I don't recall it doing that before.
Old Aug 20, 2005 | 06:26 PM
edwin's Avatar
your boost gauge is hook up wrong. Make sure it is hook up to the intake manifold and not to the fuel pressure regulator
Old Aug 20, 2005 | 06:41 PM
PapitoEVO8's Avatar
Yep, that the problem I have hooked up like this: http://www.jonesland.com/evo/BoostGauge_Install.htm The fuel pressure regulator vacuum line.
Old Aug 20, 2005 | 06:42 PM
PapitoEVO8's Avatar
Anyone have the service manual directions to where does the boost gauge line actually hooks up to?
Old Aug 20, 2005 | 06:58 PM
lqdchkn's Avatar
There's nothing wrong with that location. That's exactly where the vac/boost line should be. The reason being is, you can trust the fuel pressure regulator line to see full vac/boost pressures.
As for your gauge sticking not sure I had this a couple times with my Defi gauges and thought something was wrong with the sending unit, jiggled the lines to make sure they were secure and haven't had the issue since.
In your situation I'd tend to look at the routing from the engine compartment. maybe the line was pinched or cut somewhere.
Old Aug 20, 2005 | 07:01 PM
PapitoEVO8's Avatar
I tried that. It was working fine the day I installed it. Until today. With the car on I also pull the vacumm line of the gauge and felt no sucking pressure. I also tried anothe boost gauge (apexi) I it did the same thing.
Old Aug 20, 2005 | 08:33 PM
PapitoEVO8's Avatar
Well it looks like the problem might have fixed itself. Just came back in from checking out the evo and now it working correctly. I also forgot to mention I had washed the engine today
Old Aug 21, 2005 | 12:44 PM
DC2Dorifto's Avatar
Mine did that until I hooked it up to the fuel pressure line.
Old Aug 21, 2005 | 02:48 PM
PapitoEVO8's Avatar
Mines is hooked up to the fuel pressure line. It must have been a freak of nature. But everything is working fine now.
Old Aug 21, 2005 | 04:19 PM
04 rs's Avatar
my apexi gauge also does that every once in a while it must be the gauge, cause every turbo car i have had , i had it ran into the fuel regulater line and never had a problem
