anyone gone from ACT to a twin plate clutch?
Originally Posted by Compjoc
Twin disks have twice the surface area to hold more power without increasing the pressure plate's clamping force very much. A single disk would require more clamping force than a twin disk would.
Originally Posted by marksae
Just curious, do the people having high rpm shifting problems still have their clutch restrictors in?
Originally Posted by EvoTio
My restrictor was still in when I was having my high RPM shifting issues. The restrictor was removed yesterday and I have not had a chance to drive it. I really doubt that it will cure the shifting problem.
It doesn't grind, it just won't go into the next gear at high RPM. It shifts like butter below 5k rpm.
same thing with me...for easy driving..the gears go in smooth and nice(as if it were a rebuilt tranny!!)
but from the time u get into the high rpm range..it refuses to go in unless u drop the rpms.
no grinding at all...just doesnt want to go in....
^and i always had my restrictor in...for 3 years now..and this is the only time i'm experiencing this problem...
i never even had to adjust my clutch....not once...until now.but that still doesnt solve the prob
Originally Posted by atlvalet
I have an ACT and have no problems shifting at high RPMs. In fact, WOT drove my car. I don't think he detected anything out of the ordinary either. I have a stock, resurfaced flywheel. The ACT was installed by RRE.
Here's some food for thought... In the discussion that "all aftermarket clutch companies have this problem", I'll throw this out there...
Of the aftermarket clutchs on the market *to my knowledge* the following do NOT use a modifed OEM cover / pressure plate:
Exedy
Cusco
Ralliart
HKS
ATS
Tilton
QuarterMaster
Of the above list - only the top three allow you to retain the stock hydraulic / pull-type assembly - the others convert to a 'push style' clutch that envolves swapping many pieces of the clutch system - not just the Flywheel/Clutch.
Hope this info helps you piece the puzzle together...
Exedy
Cusco
Ralliart
HKS
ATS
Tilton
QuarterMaster
Originally Posted by 11secEVO7
to answer the topic question...I'm going from ACT to the RPS carbon twin disc.
with the ACT i'm having 'high rpm gear lock out ' problems...
hopefully the new clutch will fix it
I have my money on "not gonna fix it".
The major problem with the 'gear lockout' is the inertia of the discs... even in our Stage 1 clutch (which is a full faced organic disc) the 'lockout syndrome' still exists.
The major demon here is the weight of the disc... the actual disc itself that is spinning when engaged - but must come to a stop before the gearbox will allow a smooth shift.
When you are in the heat of the moment - shifting from 1st to 2nd - in that split second when your foot pushes in the clutch and you tell your brain to 'shift' - the clutch disc must come to a stop - or else you expierence 'lockout'.
Just like anything that carries momentum - the heavier the object, the more inertia it will continue to carry, and the slower it will be to stop... the lighter the object, the less inertia it will carry, and the faster it will stop.
When we manufacture a racing clutch, we try to minimize the inertia of the disc and that's why we use smaller discs, but more of them. They will both slow down faster and allow faster shifts - the springs in the hub portion protect the transmission for 'torque shock' which can (and will) break TCs, Axles, etc, etc...
Hope this helps...
Yup I went from 6 puck to Exedy/Cusco 6puck twins.
I have always held the ACT products in High regard but they have seriously disappointed me latley withthe level of performance and quality.
The unsprung hub destroys our drivelines.
I learned my lesson.
NO MORE ACT 6 Pucks
NO MORE ACT 6 Pucks
