anyone gone from ACT to a twin plate clutch?
Old Aug 26, 2005 | 04:36 PM
  #76
EvoTio's Avatar
Originally Posted by MattGold
I have my money on "not gonna fix it".
The major problem with the 'gear lockout' is the inertia of the discs... even in our Stage 1 clutch (which is a full faced organic disc) the 'lockout syndrome' still exists.
The major demon here is the weight of the disc... the actual disc itself that is spinning when engaged - but must come to a stop before the gearbox will allow a smooth shift.
When you are in the heat of the moment - shifting from 1st to 2nd - in that split second when your foot pushes in the clutch and you tell your brain to 'shift' - the clutch disc must come to a stop - or else you expierence 'lockout'.
Just like anything that carries momentum - the heavier the object, the more inertia it will continue to carry, and the slower it will be to stop... the lighter the object, the less inertia it will carry, and the faster it will stop.
When we manufacture a racing clutch, we try to minimize the inertia of the disc and that's why we use smaller discs, but more of them. They will both slow down faster and allow faster shifts - the springs in the hub portion protect the transmission for 'torque shock' which can (and will) break TCs, Axles, etc, etc...
Hope this helps...
This all sounds great and makes alot of sense, but I never had this high RPM lock out problem with the stock clutch. I would never miss a shift and the transmission went into gear everytime. I do not want to go back to the stock clutch again due to my plans for increased horsepower. If I were to switch to one of your Twin Disk Clutches, would my high RPM lock out problem be solved?
Old Aug 26, 2005 | 05:07 PM
  #77
03EVO583's Avatar
Tilton new clutch packages include a annular hydraulic release bearing assembly, designed to hook-up directly to the stock master cylinder with the include adapter fitting. The hydraulic release bearing converts the clutch to push-type, eliminates the mess of a external slave cylinder/linkage system, mounts directly into the transmission and self adjusts for clutch wear.
In addition, the Tilton units are lower inertia (not too low to cause drivabilty problems) that improves shifting. Tilton has a very proven (30+ years) reputation in racing and high performance applications, winning numerous race championships around the world each year.
I know of WRX/Supra/EVO owners that had problems with Exedy clutches not holding torque (non-carbon & carbon), and not had any problems with Tilton.
Tilton may not be a household name in the high-performance street market, but they sure have a excellent reputation in the demanding racing market.
Here's some food for thought... In the discussion that "all aftermarket clutch companies have this problem", I'll throw this out there...
Of the aftermarket clutchs on the market *to my knowledge* the following do NOT use a modifed OEM cover / pressure plate:
Exedy
Cusco
Ralliart
HKS
ATS
Tilton
QuarterMaster
Of the above list - only the top three allow you to retain the stock hydraulic / pull-type assembly - the others convert to a 'push style' clutch that envolves swapping many pieces of the clutch system - not just the Flywheel/Clutch.
Hope this info helps you piece the puzzle together...
Old Aug 26, 2005 | 06:25 PM
  #78
ACTman's Avatar
Hope this helps...
It doesn't... But it makes for good advertising...
Sounds good in marketing terms, but from an engineering standpoint, I disagree.
First off, the clutch disc doesn't have to "come to a stop" but it has to slow to the speed of the next gear ratio. I don't think the disc weight is the "major demon" here.
Secondly, your two slightly smaller ceramic discs are probably much heavier than one organic, with no-doubt more inertia. And there has to be air gap on twice as many surfaces.
Finally, torque shock? While I agree that the springs will help reduce certain failures, they are primarilly there to reduce transmission noise caused from torsional vibrations. Nice pitch though. Solid hubs discs like our race discs or the Tilton have proven very reliable and not likely to break parts but certainly they can be easier on syncros. I think Jeff Hill's EVO and STI are good evidence of that. Just don't expect the trans to be quiet.
Some obvious questions:
Why does it happen on some cars and not on all cars?
Why does it happen at high rpms and not at lower rpms (even to a lesser degree)?
How many people haven't addressed adjusting the clutch correctly, have the release bearing installed incorrectly or had transmission issues to begin with?
Why does this happen on the EVO and not other cars with similar or heavier clutches and probably worse syncros?
There are a lot of cars with really crappy syncros that shift at high rpms with much heavier discs than the EVO. This seems to be a dynamic issue that is somewhat unique to the Mitsubishi. Honestly, I don't know if we can "fix" it, but I am confident that we can find the root cause. From experience with other 4G63s and some race Hondas with similar symptoms, I have strong suspicions about the cause or causes. I have a host of other questions that will be answered in time with some further testing and will let us know which suspicions are correct and what we can do about it.
For the record: I am not bagging on the Exedy Twin (race clutch) and I am not saying that the twin doesn't improve the shifting on the EVO. I just don't believe the issue is disc inertia. More on that later... after testing.
Old Aug 26, 2005 | 06:36 PM
  #79
Compjoc's Avatar
How would you know if you installed the release bearing incorrectly?
Old Aug 26, 2005 | 07:16 PM
  #80
ACTman's Avatar
I haven't done an install on an EVO so I am only going by what I have heard by customers and seen in parts, but some symptoms are:
Will not shift very good at any rpm, even with extreme adjustment.
Lumpy clutch pedal (pulsation)
Vague pedal feel. It doesn't seem like a solid connection between your foot and the pressure plate because it isn't.
Broken release bearing or center components on pressure plate. The parts are usually loaded completely around. There is no reason for them to break unless they are unevenly loaded. This happens when the snap ring isn't snapped all the way in place.
Old Aug 27, 2005 | 07:43 AM
  #81
11secEVO7's Avatar
^thanks for the run down on everything.
I had liked the ACT 6 puck...hell i even did my 11.3 pass using that clutch!
hope u guys get the problem sorted out because it's a good clutch at a good price
Old Aug 27, 2005 | 08:17 PM
  #82
Compjoc's Avatar
Originally Posted by 11secEVO7
i actually changed my tranny and the problem of the 'high rpm lock out' is still there..
so this is my last option.changing the clutch.
it better work...it's so frustrating
Did you have your tranny rebuilt and it still didn't shift at high rpm?
Old Aug 28, 2005 | 07:06 AM
  #83
11secEVO7's Avatar
^no...i swapped the tranny altogether. I've got a spare evo engine and gearbox(basically like new)..
i was thinking it was the gearbox for sure. so I said what the hell..i've got a box on the ground doing nothing..let me put it in and see if it fixes the problem.
and it didnt....
Old Aug 28, 2005 | 11:46 AM
  #84
SEEYA's Avatar
and it didnt....
that is pretty interesting, sounds like there is a problem that definitely needs to be addressed in the ACT...
Old Aug 28, 2005 | 11:53 AM
  #85
Dayton_EVO's Avatar
If it is determined that this is an ACT issue with their product, are they going to incure the cost's to fix it for everyone? I just bought and installed my ACT HD pressure plate and disk, and I have not broken it in yet. Once it is broken in I will test it. If the same problem comes up, then that means ACT should have to fix it. Clutch installs are too expensive to have to front the money twice for a bad aftermarket product. I just hope I don't have this problem. Seems to me, a little more R&D should have been done. This won't be able to be passed on as all bad installs or bad Evo's! Just my $.02.
Old Aug 28, 2005 | 12:20 PM
  #86
Compjoc's Avatar
It's not just an ACT problem. I have a CM stage 3 and another a has centerforce clutch with the exact same problem.
Old Aug 28, 2005 | 12:25 PM
  #87
SEEYA's Avatar
so is it inherent in the single disc clutch design?
Old Aug 28, 2005 | 12:46 PM
  #88
EvoTio's Avatar
Yes this seems to be a problem with different clutch manufacturers. ACT seems to be a very popular clutch among Evo owners, that's why I think that the problem is showing up alot on the ACT's. When Shiv at Vishnu test drove my car after a tuning session, he mentioned that this is a problem with the single disk design. But I have heard of Exedy Twin Disk owners also complain of this issue. BTW, I got my Evo back from the guy who originally installed my clutch with the new clutch line without the restrictor in. The clutch feels so much better, but I did notice that they adjusted my clutch so that pedal is way up there. I looked under to take a look at the adjustment rod and there is hardly any thread left for any more adjustment. Also there is no clutch freeplay left either, I'm not sure that I like that. I was able to get the car to shift into each gear at high RPM, but there is still some resistance. I still can't shift as quick as I did with my stock clutch. The next step will be trying out the stock Mitsu transmission fliud to see if that will do anything. I will have to see if the guys at CenterForce will be willing to take a look at my car if the transmission fluid doesn't do the trick.
Old Aug 28, 2005 | 12:54 PM
  #89
GOKOU's Avatar
WHen you said hardly any thread left can you take a picture of it? Is it 1 or 2 thread left? I wonder how far is too far?
Thanks.
Old Aug 28, 2005 | 12:59 PM
  #90
EvoTio's Avatar
Thanks.
From my understanding, if you don't have any freeplay left, you've gone too far. That indicates that there may be some preload on the rod going into the clutch master cylinder which is not good. Mitsu specifies that there should be at least a couple of millimeters of freeplay left in your clutch pedal.
