question about 20g turbo
Old Aug 30, 2005 | 05:54 PM
EvoPanda7's Avatar
ok im thinking about getting this turbo... ima have some major parts done with cams/exaust/dp/cat/ port and polish/valve springs and retainers/ cam gears/ intercooler piping/ radiator/ reflash and so on... i was wondering can i run this turbo at 22 psi and not have to run a alky kit? w/o having problems with knock back or huge over heating problems?
Old Aug 30, 2005 | 06:12 PM
EvoPanda7's Avatar
no one again =(
Old Aug 30, 2005 | 08:10 PM
scherejs's Avatar
on good gas you could prolly get away with it. there are a few people running 22psi on 93/94 pump with stock/wr/and gt30 series turbos. it will just depend on our tune. you probably won't get a lot of timing running 22psi on pump. you will get the best benefits out of this turbo on higher boost with alky or race gas though. personally i'm a big fan of alky injection.
Old Aug 30, 2005 | 08:12 PM
MalibuJack's Avatar
Give it more than 45 minutes to get an answer.. The first batch of 20G's were recently shipped, I got mine a few days ago, so you'll start seeing data shortly. Your path is similar to the path I'm taking, I do intend to use Alky, but I do also intend to tune the car to run without it and lower boost. So I'll have information at some point in the near future.
Old Aug 31, 2005 | 07:57 PM
EvoPanda7's Avatar
thanx
how much is the 20g? and with alky do i mix it ? or where do i get the alk? i dont have to pour jack daniels down my car rite or have to give an office the "its for my car sir" on saturday nights. do i mix it with water? ive heard people do that. thanx for the reply guys
Old Sep 1, 2005 | 12:23 PM
David Buschur's Avatar
22 psi is the upper limits of boost on pump gas. 93-94 octane in good quality should work for you though.
The 20G with your core is $800.
David Buschur
www.buschurracing.com
Old Sep 1, 2005 | 12:33 PM
Soon2BEVO's Avatar
I had my car tuned by Al and I was getting 0 knock counts at 22psi... on the stock turbo. That day I made my numbers you see in my sig. This was on Sunoco 93. I usually use 94 all the time for additional knock protcetion
moey124
Nov 3, 2015 08:35 AM
mines5
20
Jul 6, 2015 05:49 AM
TURBO_S2K
32
Dec 26, 2013 01:18 PM
Srt-4 Turbo 7
Jul 18, 2013 07:36 AM
IntegxX
23
May 26, 2006 07:45 AM
